Forum Home
IntroductionBrowse
Our MacGregorExploringArticlesAbout this Website
ManualsDealer InfoSailing LinksTell a FriendSupport this Website
Forum Home
Boomkicker Banner
Honda Outboard Idle Adjustment
Moderators: Paul S, tangentair, beene, Heath_Mod, Hamin' X, kmclemore, Catigale
Postby Captain Jim » Mon May 12, 2008 7:57 am
I need a little help: I have a 50hp Honda 2005 ob on my :macm: . I need to set the idle speed up to about 900rpm; it is now set at 400 - 500 rpm. Does anyone on the board have a cut sheet showing where to make the adjustment or a reference source that I could go to on the internet?
Thanks for your help in advance..
By the way we put the BOLD VENTURE in at Lake George, N.Y. over the weekend.
Fair winds,
Captain Jim
Location: Fort Miller, N.Y.; "BOLD VENTURE"; 2006 26M Blue ; 05 Honda 50Hp 4 S
Postby Uncle Jim » Mon May 12, 2008 6:55 pm
I don't know about the '05 but on my '02 there are three carb bowls on the SB side of the engine. At each one there is an adjustment screw, ignore the top two and adjust just the bottom. This will adjust the linkage between the three units.
URL link here
I believe the adjustment screw is #47, a small turn should take care of it.
I just finished rebuilding the carbs on mine and the idle was up to 1500 !
Uncle Jim
Postby ROAD Soldier » Tue May 13, 2008 12:47 am
Do not go buy a factory tachometer it is way off. You need to use a a digitial multimeter or auto meter from a auto store for accurate RPM readings. My tach was saying I am on 1500 when I am only at 900 rpms.
ROAD Soldier
Postby Captain Jim » Thu May 15, 2008 8:21 am
Uncle Jim,
Thank-you for the information on setting the idle rpm on our 50hp motor. The adjustment of the idle worked perfectly and the schematic you linked to also is good for the 2005 Honda Outboard for the idle adjustment.
This is another example on how the members of this board share information and help one another. This is a great organization and resource to sailing. Thanks to the founders, maintainers and members.
Fair winds,
BOLD VENTURE :macm:
Captain Jim
Return to MacGregor Powersailor Discussion
Who is online
Users browsing this forum: Baidu [Spider] and 4 guests
Copyright 2004 - 2018 © HK Innovations
