Neglect your boat and this is what happens
Moderators: Catigale, Heath_Mod, beene, Hamin' X, kmclemore, tangentair
taime1
Location: Ottawa, Ontario, Canada 2004 Mac 26m, Honda BF50
Re: Neglect your boat and this is what happens
Post by taime1 » Thu Jul 28, 2016 5:07 pm
Last evening the admiral and I gave the inside a pretty good washing, just bleach and no vinegar this time. It came out ok, there are a bunch of spots that didn't come out as well as large rust rings, from having left a galvanised anchor and chain lying around for a few years.
Here are a few shots of the before:
taime1
Post by taime1 » Thu Jul 28, 2016 5:14 pm
...and a couple of the after...
Jimmyt
Post by Jimmyt » Thu Jul 28, 2016 5:45 pm
Huge improvement! Boat is cleaning up nicely.
Post by Catigale » Fri Oct 07, 2016 8:27 pm
Is that power wash? I just did one of the schools Harpoons and it came up beautiful
vizwhiz
Post by vizwhiz » Fri Oct 07, 2016 8:54 pm
More updates taime!!
taime1
Post by taime1 » Fri Oct 07, 2016 9:18 pm
I powerwashed the outside and just used rags with water and bleach on the inside.
I haven't worked on her too much lately. I did order a few thingd from BWY (rudder line, centerboard line, pop-top hold down hooks), I picked up a nice mainsail cover on ebay for $85 with shipping, and I got the trailer's fender bolt rewelded.
Not sure if I mentioned this, but the boat came with a pretty new Nissan 9.8 long shaft motor. I changed the oils and plugs and it runs nicely. That was an awesome surprise because it wasn't listed as part of the deal.
I put the mast up the other day, the standing rigging is quite loose. I don't think I will be able to adjust it sufficiently and may have to either order all new stuff, or get the existing stuff re-fitted, if that's even possible.
The only thing I am a little leary on is the wiring, I haven't gone through it, nor have I connected a battery yet.
Apologies for the lack of updates, it's been hectic. I've got two young boys, so life barely slows down, ever. That said, we've been using the :macm: as the boys night out for 3 straight Fridays where we spend the evening playing card games, or watching a movie or going fishing, and while we've used the Mac on a number of family vacations now, this alone time has been something very special.
They do ask me how come they only get one juice I get four or five beers, but that's another story...
Man, I love these boats.
Post by Catigale » Sun Oct 09, 2016 7:02 am
Is the 100 dollar boat deal? That Nissan is worth about 3k new!!
Well done!
Tell Justin to fund NRC for a bunch of lasers and I'll make the trip up to Ottawa to help with. The wiring on the company dime.
My Mistress
Post by My Mistress » Sat Oct 15, 2016 7:25 pm
taime1 wrote: Not sure if I mentioned this, but the boat came with a pretty new Nissan 9.8 long shaft motor. I changed the oils and plugs and it runs nicely. That was an awesome surprise because it wasn't listed as part of the deal.
The only thing I am a little leery on is the wiring, I haven't gone through it, nor have I connected a battery yet.
Good deal on the motor! That was worth the price itself.
If I may be so bold, but you should have used Simple Green for your cleaning. It's non-toxic and does a great job on fibreglass. I cleaned "Mistress" inside and out using Simple Green and water.
I know where you're coming from on the wiring. I was aghast at all the different types of wires running every which way, and most weren't even hooked into the system. One evening, while contemplating what I was going to do with the galley light, I broke out a VOM and started identifying active circuits and pulling out old or unserviceable wire. Now, I am pretty much done with the re-wiring. 12V is actually pretty simple.
Hint - go with LED lighting throughout.
taime1
Post by taime1 » Sun Oct 16, 2016 8:47 am
The motor is quite nice. Here are a couple of pictures. Not sure why Tinypic flipped them on their side...
I do wish it had forward/reverse selection on the tiller handle, but I can't really complain. I hacen't hooked it up to a battery, but it appears to have electric start and charging, which is nice.
I do have one engine-related fix to do. I need to figure out what sort of cover I should put on the hole from the laz to the engine well that is used for the fuel line:
I think I can just get a larger clam type cover and that should keep the water out. The PO has a small one, loosely attached only at the top, but I didn't like it.
vizwhiz
Post by vizwhiz » Sun Oct 16, 2016 10:45 am
Post by Catigale » Wed Mar 22, 2017 6:45 am
taime1 wrote:The motor is quite nice. Here are a couple of pictures. Not sure why Tinypic flipped them on their side...
That's a clone of our kicker motor. I'm expert in three things on this..
1. Replacing broken gear shift from a drop
B. Replacing stripped final drive gear from hitting steel cable on Cape
III. Dunking this motor 3 times in fresh or salt water and recovering.....ok, 4 times
