'88 26D Rudder Assembley
scrawley
Sailboat: MacGregor 26D
Post by scrawley » Tue Jun 23, 2020 7:19 am
I need help with the "kickup rudder assembly" on my boat. I've attached a pic showing the 1/4" line setup but I don't think it's correct. I've searched for an illustration showing the correct rigging but can't find anything. Can someone provide a photo for me to mimic?
Interim
Re: '88 26D Rudder Assembley
Post by Interim » Tue Jun 23, 2020 10:37 am
Mine doesn't have the shiv and fairlead system that yours has. My line just goes through a hold in the rudder (toward the trailing edge).
You should also have a wire attached to the leading edge that comes up through the rudder post to hold the rudder down. Attach with a bungee so it will give way if you hit.
--john
Curwen
Post by Curwen » Tue Jul 14, 2020 12:27 pm
That is not the stock setup for the rudder.
I see there is a plate on the back of the rudder assembly to stiffen the assembly. That is on the list of things to do over the winter.
