New Custom 26X Trailer
Moderators: beene, Hamin' X, kmclemore, tangentair, Catigale, Paul S, Heath_Mod
- vkmaynard
Re: New Custom 26X Trailer
Just heard from Triad today.
"Finally! I’ve finished up the pricing file which is attached. The same trailer as yours is going to start at $3,990.00. There have been a ton of steel increases over the past couple of months which really raised the pricing. Everything on the trailer is pretty much steel. Hopefully the markets have calmed down a bit."
https://www.dropbox.com/s/ttisqajrphjrc ... 8.pdf?dl=0
Still a deal considering all the MacGregor mods including a custom 102" single axle for a 26 foot trailer with wheels that don't rub the hull.
Not advertising for Triad. Just trying to get a great trailer source for our Mac family.
Victor
Victor
- sailboatmike
Do you find launching and retrieving much better with the roller on the bow bunk??
Does the bow roller mean you dont have to dip the trailer so deep?
Does the bow roller mean no more Mac Bump??
- Location: NH, 2001 MacGregor X - Tohatsu 50 / 2013 Ford F150
I have a Sea Lion trailer, and like the Triad pictured, I had to install that same roller under the bow. It doesn't have anything to do with the Mac Bump, but rather to keep the boat bow from being gouged by the end of the tongue tube.
- vkmaynard
The bow roller does reduce how far you need to dip the tailer since the bow can roll up instead of digging in like K9Kampers wrote.
I noticed key features missing on the pdf: side rails extended up to the hitch for better stregnth, cross bracing, lengthened trailer for better support, axle moved back to reduce sway and mid bunk slightly moved forward to rest swing keel and avoid dropping during transport (26X).
Victor
Victor
- sailboatmike
Awesome thanks, I was thinking of this mod even before you got your trailer made after watching other 25 foots boats hauling out without having to splash the whole trailer, I identified the bow bunk as a major issue to the depth required for the trailer, I would think this could save as much as 3 feet of distance from the water edge as the rear and middle bunk are plenty deep enough to push her off long before the bow bunk gets anywhere near the water linevkmaynard wrote:The bow roller does reduce how far you need to dip the tailer since the bow can roll up instead of digging in like K9Kampers wrote.
Victor
Great job on the ad/flyer/brochure, I emailed this morning to place an order.
- vkmaynard
First trip on the new trailer last weekend.
Wow! No problems towing, launching in shallow water or single hand retrieving (first time auto center).
No sway, no tire rubbing just no problems anymore.
Fully loaded the boat and towed with confidence. Disk brakes worked great!
Thanks Triad!
Victor
Thanks Triad!
Victor
- vkmaynard
Dan finally got his 26M Triangle trailer done. viewtopic.php?f=11&t=27070
Reports better towing and NO sway.
That means they can make trailers for both models now.
Victor
Victor
- dlandersson
I have this on my Mac trailer (an after market add). I like it a lot.
K9Kampers wrote:I have a Sea Lion trailer, and like the Triad pictured, I had to install that same roller under the bow. It doesn't have anything to do with the Mac Bump, but rather to keep the boat bow from being gouged by the end of the tongue tube.
I wonder if anyone has ever had this trailer built for a Mac 26S? I'm very interested in a new trailer based on retirement plans.
I also would love to hear about it if anyone had it built for a Mac26S before. Also would love to hear if someone tried it in Europe. I want to try this anyway but it would be great to hear some other experiences. I'm going to be retired by the end of the summer and thinking about moving to Greece. Right now I'm looking for a house for sale in Athens by the shore and as soon as I buy a house I want to start. I'm gonna have plenty of time to work on it.sturmgewehr wrote: ↑Mon Jul 15, 2019 10:32 amI wonder if anyone has ever had this trailer built for a Mac 26S? I'm very interested in a new trailer based on retirement plans.
Has anyone investigated using longitudinal bunks rather than the lateral crossmember bunks that come standard for either the X or M? I am planning on building an aluminum trailer and was considering using the non stock yet more conventional bunk arraignment and wondered if anyone has info?
