Herschel wrote: ↑Thu Aug 27, 2020 9:13 pmTom, that is super useful. Thank you. Would love to see the floor plan of your unit. Or a link to one.
Well, since you asked so nicely.
600Ah LiFePO4 battery with 3000W inverter, which can run the roof air on battery for hours, but no generator (didn't want one). There's a 280A second alternator on the engine that's dedicated to the house electrics. 300W of roof solar, which more than keeps up with the 120/12V compressor 2-door fridge/freezer which is about 70W when it runs.
Jack-knife couch folds out electrically to a king bed, though I think twin beds might have been better for old folks like us (easier to get in and out of), though not good seating for traveling. Seat belts for 6, though I may take that single second row seat out to make room for a soft-sided dog crate.
Propane and/or electric heat and hot water, with pressurized water. It only has 40 lb of propane, but it's plenty if using electric heat when on shore power; I've only filled it once since I got it, and we mostly travel in cold weather (to where the warm weather is
). Wet bath is bigger than the
, but not by a lot. Full standing room in there, though, with a real pressure flush head. Sink, too, but like the
, why bother? The galley sink is right across the 'hall'. Standard is a single-burner induction cooktop (no oven), though this one had the optional 2-burner propane cooktop which was removed and replaced with a 2-burner induction cooktop. Induction is nice in that it's flat when not being used, so the counter space is generous. We run that off the inverter, too, when boondocking at rest stops and welcome centers and can't plug in.
I'm looking into air ride suspension for the rear, as it rides like a truck back there, as you might expect (it
is a truck, with a van body, after all). Kelderman makes a series air bag system that replaces the shackles on the rear of the leaf springs, so the original springs are retained but the aft end is mounted to an air bag system. And there's VB Air Suspensions, which seem to be an M-B approved retrofit which can be ordered when you buy a van, and completely replaces the entire rear suspension - everything but the axle. Mo money, too.
Can also be had with 4-corner air suspension, popular with ambulances in Europe.
BOAT has a nice setup in a Sprinter, too, but his is custom.
