Tow boat, slip to ramp
Julia
Re: Tow boat, slip to ramp
Post by Julia »
If you need to move your MacGregor 26X from a slip to the launch ramp, the easiest way is to get assistance from a neighbor or local boater. If you have a BoatUS membership with TowBoatUS coverage, they can tow you from the slip to the ramp. Make sure ballast valves are open so water drains as you pull onto the trailer. A dinghy or small boat can also be used to tow if needed.
