Sory for posting unrelated to this section.
I'm actually registered to post something in European Group of this forum, but once I log in European Group disappears together with Rest of the world. I tried to contact administration, but without any result, so using this way, as I haven't found any better place.
Can someone tell me is it a bug or feature? If it is a bug, can you fix it?
Thanks.
Sorry for this post - why european group isn't visible when logged in?
- kmclemore
- Location: Ambler, PA -- MACX2018A898 w/ Tohatsu 50D -- 78 BW Harpoon 4.6 -- 2018 Tahoe 550TF w/ 150 Merc
Re: Sorry for this post - why european group isn't visible when logged in?
I’ve just posted a test message to that forum and it worked fine. However I’ve contacted Russ, the forum owner/manager on your behalf and I’m sure he will contact you as soon as he’s able. Please ensure the email address you registered with here on the forum (syom****@gmail.com) is correct.
- kmclemore
From what I can see from administering your profile, you were not a member of those groups. I updated your profile to make you a member. Try it now.
- kmclemore
Russ tells me the problem should be fixed now. Give it a try and post back to let me know.
Hi, sorry for late reply
Now I can see the group, but when I open it, I get
"You do not have the required permissions to view or read topics within this forum."
So it's not fixed really.
Permissions on that group were set wrong. It also required members to be invited into the group.
I changed it and made it fully public. Give it a try now.
And thanks for bringing this to our attention.
Thanks Russ.
Now it works, you can delete this topic.
Regards
Lingvo
Regards
Lingvo
