New Mast for 26X
Popscott
Location: Bayview, Idaho "Huff and Puff" Evinrude E-Tech 60
New Mast for 26X
Post by Popscott » Wed Jul 22, 2015 3:02 pm
I currently have a rotating mast and would love to replace it with a new mast. Can somebody provide any leads where I can purchase a new mast for a 26X
Thank you,
Ryan Scott :macx:
Chinook
Re: New Mast for 26X
Post by Chinook » Wed Jul 22, 2015 3:36 pm
I'm curious about having a rotating mast on an X. The X rig includes a back stay, which I wouldn't think would allow installation of a rotating mast. Position of shrouds and spreaders precludes eliminating the backstay when sailing downwind, as I understand it. Blue Water Yachts can fix you up with a new mast, but not sure how far away you are from the Northwest. Shipping cost becomes an issue.
Popscott
Post by Popscott » Wed Jul 22, 2015 4:07 pm
I'm the second owner of the boat, and I hired a master rigger up in Bayview, Idaho (lake Pen Orielle) for a consultation and he said my life would be much easier if I got a new mast. Currently for the rotating mast I have baby stays and two backstays (with adjustment). Blue Yacht quoted me 680.00 for the mast.
Ryan Scott :macx:
Chinook
Post by Chinook » Wed Jul 22, 2015 5:07 pm
Did that include shipping, or are you close enough to bring the boat to them?
Post by Russ » Wed Jul 22, 2015 5:35 pm
Easier....maybe. But rigging a new mast is costly. Not sure how much easier $1000 would buy you. On the other hand, there are probably Mac X owners here who would love to trade you masts.
Popscott
Post by Popscott » Wed Jul 22, 2015 7:45 pm
The cost of shipping is around 200.00. Lot cheaper then driving to Seattle and taking a day off of work. The master rigger hinted the cost won't be that munch, my current mast has problems such as: poor halyard block placement for furler, needs new shrouds due weak points. On Friday I'll take pictures of all the current problems and post them on the forum. It's a lesson of why not to go from an original :macx: mast to a :macm: mast. It's a learning experience.
kadet
Post by kadet » Thu Jul 23, 2015 12:27 am
Why do you need a new mast? Is the extrusion damaged in some way? If it is just because you don't want a rotating mast remove the rotator cup at the bottom and have someone fabricate a fixed plate or get the rotating one welded along with the rotating spreader mount, no new mast should be needed unless it is damaged.
Also remember the :macm: mast is taller than the :macx: so if the sails were updated as well you will need to get them resized to fit the :macx: mast. 8)
Post by Russ » Thu Jul 23, 2015 7:34 am
kadet wrote:Why do you need a new mast? Is the extrusion damaged in some way? If it is just because you don't want a rotating mast remove the rotator cup at the bottom and have someone fabricate a fixed plate or get the rotating one welded along with the rotating spreader mount, no new mast should be needed unless it is damaged.
Yea, this makes sense. Seems like it's harder to go the other way (make a fixed mast rotate). Lock it up and move the extras.
Popscott
Post by Popscott » Thu Jul 23, 2015 8:21 am
Thank you Kadet, that does make sense. I'll look into that. :macx:
