It has a double bow construction with connectors. At the top center is a removable mast roller.
The arch mounts to stainless plates bolted to the inside surfaces of the transom. The upper mounting tube is in the exact same location as the factory mast carrier so you can switch between the large arch and the factory mast carrier arch. The second lower tube creates a very solid mounting base for the large arch to lock into.
Here's a shot of the boats at the rendezvous, I'll have more pictures up at my website soon. The weather made the trip to Port Townsend very rough with winds of 20-30 knots in Admiralty Inlet and the eastern part of the Strait of Juan de Fu c a. Over 15 boats canceled due to weather, so we only had about 35 Mac's in attendance. It was still a great party though.
