Duane Dunn, Allegro wrote:It's pretty easy over time to know how much your engine consumes at a given rpm level, and this never changes.
Duane, I appreciate your response and I understand what you're saying, but ... you're a power-boater, even if your powerboat is a MacGregor. I'm a sail-boater even though I have a Honda 50 on my transom, and I might go through two tanks of gas a season; during that time I may vary from kicking out of my harbor at 1500 RPM to dumping my ballast to get somewhere quickly at 5000 RPM. I'm not sure your case applies to mine very well....
The tendency however it to adjust the throttle to hit a target speed instead of an rpm number. This happens both in heavier conditions and against currents. This leads to using a higher rpm setting than you intend to use and burning more fuel. For some reason we never are happy with the slower speed a contrary current gives, and when we have positive current help we never back down the rpms either instead we just enjoy the extra boost.
The very names of our boats bespeak our different attitudes about boating, don't they?
"Bossa Nova" is Brazilian jazz; often slow and languid, sometimes fast and bouncy, but always "swings so cool and sways so gently" (as in the English lyrics to 'The Girl From Ipanema') ... like sailing.
"Allegro" means one thing in music:
fast.
A cheaper and very useful addition is a speed through water transducer. With this you can get two speed readings on the GPS, speed over water from the paddle wheel and speed over ground from the GPS. This let's you see the effect of any current.
I have one, installed by the P.O. as part of my old depth-sounder, and I have never been satisfied with its behavior at those "languid" sailing speeds. Seems to me you have to be going "allegro" to get a trustworthy reading out of them.
Another simple addition is to spend a bit more money for the enhanced tide and current tables for your area instead of the simple tide book. At least up here in the Northwest, just because there is a flood tide it doesn't mean all the water is flowing south through the sound. Having this little extra information will let you plan the route and time that will give you the most current help under sail or power.
Now that's advice that might apply even more valuably to a "sail-boater". You're absolutely right with that! Tides and currents make a difference that becomes ever more marked and critical at slower speeds - like sailing - although the power-boater is indeed likely to push the throttle a little more heavily in the face of an opposing current, thereby burning "extra" fuel.
I do agree that you can learn your engine's fuel-burning habits, over time, if you're using the engine as your sole source of motive power and you're using it at a fixed RPM between fill-ups. I know the fuel burn of my airplane, but I always cruise it at 2300 RPM (taking what speed I get); and my 150-hp Lycoming uses 8 gallons per hour at 2300 RPM and about 2000 feet. That's not how I sail Bossa Nova - for now it's an afternoon under the canvas, rather than "I have to get there at X o'clock." But if I do start using it more as a "traveling machine" - for example, doing the Bahamas and having to cross the Gulf Stream - I will need to know my fuel-burn and my best-range throttle settings, and the way I'm using my engine I'm just not learning them as fast as you did.
Or as "allegro".
