Motoring with just the rudders?
Mr Seas
Re: Motoring with just the rudders?
Post by Mr Seas » Mon Jan 29, 2018 6:42 pm
Mr Seas, Blake, hails out of Southern Utah near Zion National Park. Our Boat is called Mrs Seas.
Post by Russ » Wed Jan 31, 2018 9:48 am
Neo wrote: I was wondering what it would be like if I centered and fix the OB, then under low power, just steered with the rudders .
Yes, this is what I do all the time.
I only connect the motor to steering when docking. Then I use the BWY quick connect and attach the motor centered once I clear the marina.
Of course high speeds you need to pull all fins up and reconnect motor.
This works well for sailing as I can then tilt motor up with sails or drop it when under power.
Yes, if you need a tight turn, you'll want to drop a board to give some grab, then pull it back up. If you have a really tight turn (like in a marina) you'll need to reconnect the motor.
Neo
Post by Neo » Wed Jan 31, 2018 10:22 am
Thanks Russ 8)
DaveC426913
Post by DaveC426913 » Sat Feb 03, 2018 10:20 pm
In my experience, motoring w/o the C/B makes for very wide turns.
It would be OK in open water, but I've had some major sphinctorial puckering in the harbor when forgetting to drop the C/B.
sailboatmike
Post by sailboatmike » Sun Feb 04, 2018 2:22 am
DaveC426913 wrote:In my experience, motoring w/o the C/B makes for very wide turns.
I know what you mean, when that channel marker is coming up rapidly and your just skating across the water instead of turning away from it, a highly puckering moment :?
Post by dlandersson » Sun Feb 04, 2018 3:30 am
Yeah, that sums it up nicely 8)
Post by Russ » Sun Feb 04, 2018 9:51 am
That's interesting.
The M does turn wider without board, but not like what you X owners are describing. I've found myself in the marina with poor turning and realized I forgot the board down.
Can't you drop your centerboard just a few inches to get a good bite? The M's dagger needs to go down much more to achieve the same surface bite.
I have dropped the dagger a bit at certain speeds to avoid the motoring "wobble/zig zag".
Post by Tomfoolery » Sun Feb 04, 2018 10:03 am
RussMT wrote:Can't you drop your centerboard just a few inches to get a good bite? The M's dagger needs to go down much more to achieve the same surface bite.
The :macx: has that long swing CB, which makes a pretty effective 'skiff keel' with only a little showing.
RussMT wrote:I have dropped the dagger a bit at certain speeds to avoid the motoring "wobble/zig zag".
I can't speak to the :macm: behavior at just under hull speed, but my :macx: wanders all over the place without some CB, even if it's only shallow. And one rudder at least. But then, I hardly ever open it up these days, so I rarely move without boards down. :|
DaveC426913
Post by DaveC426913 » Sun Feb 04, 2018 1:20 pm
RussMT wrote: Can't you drop your centerboard just a few inches to get a good bite?
A little or a lot'l. As long as you remember to put some down.
I've got a few dock-splinters in my prow from Launch Day, forgetting to lower the C/B (after six months on-the-hard).
[ EDIT ]: My boat has. Not me personally. I have no dock splinters in my prow. And I sure don't leave it on-the-hard long enough that I forget how to use it.
Neo
Post by Neo » Sun Feb 04, 2018 1:57 pm
DaveC426913 wrote:[ EDIT ]: My boat has. Not me personally. I have no dock splinters in my prow. And I sure don't leave it on-the-hard long enough that I forget how to use it.
Careful ... you could be banned from this site. :D ... Small fonts won't protect you :wink:
