How much rake? ....
Signaleer
Location: Foley, Alabama...2002 26x & 2002 90 HP Mercury Salt Water 2-stroke
How much rake? ....
Post by Signaleer » Sat Apr 28, 2018 6:05 pm
... is too much?
Mainsail will be about 1 foot lower on the boat.
(and yes, i think this is too much.)
Think I should sail her like this?
I will have to replace uppers and lowers for this new mast.
J24 Mast Spreaders. Mast off some catamaran.
Ed.
Signaleer
Re: How much rake? ....
Post by Signaleer » Sat Apr 28, 2018 6:50 pm
Actually, is this as bad as I thought?
My image is not perfect... I'm not exactly beside it.
How bad would you call this?
Ed
Post by Jimmyt » Sat Apr 28, 2018 7:15 pm
http://www.ne-ts.com/mac/xx/xx-211tuning.html
Ed,
2 to 4 degrees, according to the NETS gang. Maybe some of the experienced x sailers will chime in.
You’re probably going to want to get a better setup for determining the angle before you start dialing it in.
sailboatmike
Post by sailboatmike » Sun Apr 29, 2018 2:41 am
1 1/2 to 2 degrees I find good, however if you are a newer sailor 2 to 3 degrees which will cause the boat to round up easier if over powered. rounding up is preferable to getting knocked over and losing confidence
Starscream
Post by Starscream » Sun Apr 29, 2018 6:48 am
I think the only way to really tell is to get out and sail. Then fix the rake based on weather/lee helm. My X will round up early and often in gusty winds because the rig is raked backwards kind of like yours (can't really tell from pictures...). The boat is in my driveway right now, and I just adjusted the backstay and sidestays to lessen the rake, and now I have to get out there and fix the sagging furler. Not looking forward to that, but at least the second forestay that I installed a few years ago will hold the mast up while I make the adjustments.
It's a drag to do with the roller furler, since you have to access the turnbuckle inside the drum each time you want to make an adjustment.
tlgibson97
Post by tlgibson97 » Mon Apr 30, 2018 5:43 am
Correct me if I'm wrong but the rake should be set with the angle in relation to the water. I had mine initially set referencing from the deck but my boat was very stern heavy at the time making the rake way too far aft. It wanted to round up with every puff and was a real chore to keep on track. I raked it more forward and the handling greatly improved.
Post by Tomfoolery » Mon Apr 30, 2018 7:48 am
tlgibson97 wrote:Correct me if I'm wrong but the rake should be set with the angle in relation to the water. I had mine initially set referencing from the deck but my boat was very stern heavy at the time making the rake way too far aft.
Yeah, the manual (as it were) shows rake set to the foredeck, but that assumes a certain attitude of the hull to the water.
Post by Tomfoolery » Mon Apr 30, 2018 7:52 am
Starscream wrote:It's a drag to do with the roller furler, since you have to access the turnbuckle inside the drum each time you want to make an adjustment.
But then, the only time I've ever messed with the forestay adjustment is when I first got the boat and replaced the forestay, and then again when I wasn't happy with the rake.
My highly technical and carefully engineered procedure is to adjust the rake with the forestay first, and then the tension with the upper and lower stays. Backstay is just an afterthought, in the case of the :macx: . 8)
