The difference between jib and genoa cars?
richter372001
Post by richter372001 »
Hi, all
I'm buying a 150 Genoa. Is it necessary to buy new cars for it? Do the jib cars not work for Genoa?
Srdjan
delevi
Post by delevi »
No, they don't. Not very well anyways. Jib cars only have lateral movement. They don't swivel by design to keep the sheet feeding straight back to the winch. The genoa cars need to swivel so the sheet can go forward to the winch. A set of genoa cars runs $60-$70.
Leon
Hardcrab
Post by Hardcrab »
However, jenny cars can work perfectly fine as jib cars, but not the reverse, as delvi points out.
Or EZ cleats from Bill of course.....
I do not believe Roger sells the jib cars anymore. He just ships the Genny cars, whether you have a jib or a genny.
As for the EZ cleats.... DO NOT USE THEM!!!
I don't care who sells them.... :!:
They will bend, snap right off, the bolts will pull right out of their sockets, you name it, it will happen. As it has to me. Always use the winches.
I use mine now, just to raise and lower my bumpers..... for that.... they are great.
Terry
Post by Terry »
beene wrote:I do not believe Roger sells the jib cars anymore. He just ships the Genny cars, whether you have a jib or a genny.
Yes, I heard the same thing from the dealer, glad I got a set of each, but I started out with a jib and got the genny later. Perhaps it because headsails are now an option and most elect for a genoa on a furler. If Roger no longer sells them I'd get them elsewhere but I'd get them.
I love my EZs, especially with kids in the cockpit - it cuts down on the neck grabbing lines for them.
You've got to start sailing without hiking out, G.... :D
My EZ's were fine.... until I started sailing in winds over 25kts.
That is when they stared showing their...... shall we say... limitations.
As far as hiking out, if I didn't do that, she'd be rounding up all the time in those high winds. :|
But the good news is, which I am sure you will like, I finally got one of those fancy inflatable life vests. So I will be actually wearing a life jacket while hiking out/single handing/etc this summer.
Cutting the hedges with the lawn mower again, Benson???
:D :D
Is that with, or without a tether :?: Also, how long a tether :?: Will you be dragged along behind the boat, or, dangling like a piece of meat, arms flailing :?:
I seem to be in a noir mood :evil:
Post by K9Kampers »
Ray -
Would that be a Pinot noir mood? :)
A red, feisty wine. Difficult to find a good example of. Yes, that would be me. :evil: :wink:
delevi
Post by delevi »
My ez cleats didn't fail, probably because I didn't use them long enough for that to happen. There is no way to trim a sheet w/o the winch unless you're in really light winds. I don't like the idea of luffing up to trim the headsail... just aint right. Anyone want a pair of ez cleats real cheap :wink:
As for the genny cars, KH can sell you a pair. I'm sure BWY would too.
On edit: I don't think genny cars are the best thing if flying a jib. I'm sure they'll work, but the sheeting angle may be compromised due to the cars swiveling vs. the jib car which will only pivot on its axis but won't twist out to leeward. Should keep the clew at a better angle and provide a more direct feed of the sheet to the winch. Just my humble opinion... I haven't actually tried the genny cars on the jib track since I have a set of each.
Leon
johnnyonspot
Post by johnnyonspot »
I've literally never had to use the advantage of a winch in order to trim my job sheets. I can imagine it might be different with a big genoa, but with my working job I can muscle it no problem. I just got some EZ cleats from Bill last December and hope to be able to use them sometime this year, if I don't sell my boat first. Anyone know anyone interested in a 1983 Mac 25... with unused EZ cleats? :wink:
I've also never used my winches for trimming the Genoa. In fact, I've never used my winches.
