Companionway panel help please
cuisto
Post by cuisto »
I spent 3 years in a marina where my whife and i were the only people who overnighted. Noise was no issue. We have now moved to a new slip in a marina mostly occupied with overnighters. I work untill late in the evening and then we take off to the boat so we can wake and take full advantage of the day, we arrive in the dark around 1200 or 100 am.
Problem: The stock companionway pannel is large, bulky, clumbsy and NOISY.
Solution: will be making more traditional pannels (Ithink they are called batter boards)
I stupidly forgot to measure the originals dimentions last weekend. Would someone with their 26X at hand be willing to grab some measurements for me?
I need top width
bottom width
heigth
thickness
any help would be appreciated.
Thanks guys!!!
pokerrick1
Sailboat: Venture 23
Square
Post by pokerrick1 »
Is it a rectangle?? If not, top and bottom measurements won't help much. M isn't rectangle it's tapered and smaller at the bottom.
Rick :) :macm:
cuisto
Post by cuisto »
work with me pokerrick,
I can figure it all out by centering the bottom dimention under the top one using the height axis as the center point of both. Guys if i have this wrong SHOUT at me.
pokerrick1
Slow
I am trying to work with you, Sir, but you have to remember that I am very slow and not too bright. :) :( :? - - - and I no longer remember what a height axis is :| I am very much age and memory challenged. I can barely remember how many wives I've had sometimes (easier to just count the monthly checks) :D
Rick :) :macm:
Billy
Post by Billy »
My X companionway panel measures:
Top width : 35.25"
Bottom width : 21.5"
Height: 33.5"
Thichness: 3/16" (I've used 1/4" plywood in my guides without a problem.)
Hope this is what you are looking. :)
cuisto
Post by cuisto »
Thanks Billy Perfect
Anyone want to post the M measurements. I'll put them together so it could be searchable.
March
Post by March »
My 26X came with a companionway door (is this the panel we're talking about?) made of plexyglass. It's easy to handle and light--in both senses. Problem is, it is also hard to discern when laid out on the aft beds. I kneeled on it last year and it cracked. Plan to have another one made after it this year, even though it might cost $100--maybe a darker hue but basically the same idea
Beam's Reach
Location: North Bay, Ontario, Canada 97X, 50HP Mariner 4 Stroke
Post by Beam's Reach »
My X came with the batterboard made from dark plexi glass. The top and bottom edges are bevelled so they fit together better and shed rain. They let is some light but are hard to see through from outside providing pricacy. Very easy to store. We never use the factory panel anymore.
cuisto
Post by cuisto »
Beams Reach,
Exactly what i'm after.
A friend of mine owns a glass shop. repairs windows etc. He will cut and bevel a tinted lexan sheet for me. Just needed the dimentions.
To all, thanks again!
LOUIS B HOLUB
Post by LOUIS B HOLUB »
March wrote:My 26X came with a companionway door (is this the panel we're talking about?) made of plexyglass. It's easy to handle and light--in both senses.
We made our hatch-door of smoke tint Lexan. I attached a small stainless handle, and S/S lock rasp which aligned with the lock unit on the sliding upper Hatch. The extra light & transparent door makes the cabin much nicer. For privacy, removable curtains are used.
For the A/C, we used 2 pieces of plyboard, cut away for the A/C, and the top half is removable for cabin entry.
All these are easily stored on the front birth when underway.
MSN-Travelers
Location: SE Wisconsin ... "Witchcraft" ... `99 Beneteau Oceanis 352 w/ Yanmar 27
26M
Post by MSN-Travelers »
My M companionway panel measures:
Top width : 31.5"
Bottom width : 27"
Height: 22 5/8""
Thichness: 3/16" (1/4" would fit fine too)
__________________________
Paul
pokerrick1
Dementia
cuisto wrote:Beams Reach,
(sic)
I need a little dementia myself sometimes :D
Rick :) :macm:
Beam's Reach
I guess that does make you (sic). ;)
pokerrick1
Fosure
Beam's Reach wrote:I guess that does make you (sic). ;)
Absolutely :)
Rick :) :macm:
Cuisto,
Highlander has a very interesting companion way cover on his 19. He may be creating a new one on his new M. It is made of plexi, but in the middle of it there is a large oval window (something like the Nautilus in Walt Disney's 20,000 leagues under the sea). I'll e-mail John and see if he can post a picture of it. You may be very interested.
