Glenn
White Plugs
- The Mutt
White Plugs
Anyone know of an Aussie supplier of the white plugs used inside the cabin of the
to hide the nuts that hold the deck hardware on.
Glenn
Glenn
Boblee
Re: White Plugs
You could try Synergy Yachts the Australian dealer which I must do too one day as I need a couple and some paint to blend them.
- The Mutt
Re: White Plugs
Thanks Boblee
I didn't realise Synergy Yachts did spare parts as well. I'll give him a call when we are working his area next.
Glenn
Glenn
ubi_est_via
- Location: Melbourne, Australia. "Deja Blue" 2008 M 50hp E-Tec
Re: White Plugs
Hi,
Blue Water Yachts in the US will post them to you. I think the URL is www.bwyachts.com They cost less than 50c each. They also have the fawn ones that match the interior lining of the M....Cheers, John
- The Mutt
Re: White Plugs
Thanks for that John.
I have to work out how many and what sizes I need before I buy any, I'm systematically going through our
removing the plugs, undoing the bolts for the deck hardware, etc and resealing, there are a few very small but annoying leaks from some of the bolt holes so I thought I'd do the lot, only problem is that the plugs sometimes break.
I also have a small leak from the anchor locker drain tube, I am about to pull out the foam to install an electric winch to raise the mast and add an Anderson plug so the tow vehicle can charge the batteries while on a long trip, I'll reseal the tube while there.
Glenn
Glenn
