Just wanted record my hull-bottom painting experience. It was a fun and worthwhile project, but was about 10 times the work that I had hoped
I sail in the Great Lakes which are reknown for slimey/calcified build-up if you don't have ablative paint on the hull. Last year, when I pulled it from the water, I couldn't get the scum off of the factory gelcoat with any amount of powerwashing, Starbright Hull Cleaner, scrubbing, etc. I actually got angry once and tried my random orbit sander to see what it would do and it quickly took the grit off the paper without touching the crust on the hull.
After some web research, I discovered that toilet bowl cleaner (in my case, The Works(tm)), did the job quickly and easily. I'm not sure I would advise the annual use of toilet bowl cleaner (a hydrochloric acid solution) but the one-time application left the hull shiny and new looking, with no obvious etching or damage.
I rented two jackstands from a local marine shop and prep'ed the hull with...
1. Toilet bowl cleaner
2. Hot power washing - (not too hot and not too powerful)
3. Hand scrubbing with Scotch pads
4. Acetone dewaxing
5. Hand sanding with coarse-grit sanding pads
6. Rub-down with Interlux V-172 solvent (alcohols)
7. Two coats of Interlux VC-17m Extra with teflon, copper and Biolux (rolled on with a smooth-knap paint roller).
VC-17 dries almost instantly so you have to keep moving, or wait about 10 mins before continuing. It stuck on very well and seems like it will stay there. The color selection is limited - Copper, Red and Blue. I was afraid the blue wouldn't match so I chose the copper. It's actually a clear paint that you mix copper powder into before you apply. It's shiny at first but will turn very dark after it's in the water for a week or two. BTW - I laid down some wax-paper on the bunks before letting the boat rest back down on them.
On Edit: The two coats of paint took just under 1 gallon total. I mixed all four quarts of VC-17m into a milk jug (with the copper) and only poured what I needed into a small roller tray. VC-17 dries verrry fast - this way you won't end up wasting a lot of paint.
Anywho, I'm hoping not to repeat last year's troubles with growth and cleaning. I'll let you know how it goes...
~Bob pics...
