Have you ever done that type of improvement ?
What type of porthole did you fixed ?
There is a lack of ventilation in the Master and Mistress cabin ...
No bad though !!!
Thank you.
Ray, your ports look like they're in a similar location to the ones I added this October to Bossa Nova. What did you use, Beckson ports?NiceAft wrote:I had opening ports installed in the cabin, and I think they are wonderful. Our ports are located in the aft part of the cabin, not in the aft sleeping area. You can see the starboard port in the photo below.![]()
You should close all port when you leave the boat, and while sailing.
I believe someone did do a rather unusual mod for ports in the aft sleeping area. Instead of placing the ports on the sides of the boat, I believe they placed them where your heels would be touching when you sit in the cockpit.
