Duane Dunn, Allegro wrote:
I've often considered plumbing mine in as they have all had the needed fittings, but then you're stuck when you bring the boat home. I've decided it's more versatile to just stay un-plumbed and dump it normally. We have been in situations where were at anchor in front of a park and needed to empty the tank. It was easy to put the tank in the dinghy and take it to a restroom on shore. One time up in Canada (where they still allow overboard discharge in open water) we were in a bind and were able to empty it over the side. You can't do this once you plumb things in to the deck fittings.
Duane, I have the same unit you have (Dometic 975 MSD), and have it plumbed it, with a deck pumpout and the side airvent. It takes less than a minute to convert it it from permanent plumbed-in to removable, so I can empty both ways : either via deck pumpout or removing the whole unit. Going from plumbed-in to removable takes a simply twist to get the hose assembly off and replaced with the spout attachment. Then pulling out the lock-in base-clip frees the unit from its floor mount. The process is quick and easy - just keep a disposable plastic bag around to temporarily keep the unattached hose end in.
After a careful study of most of the options, I think this unit, with its dual mode (portable vs plumbed-in) is probably one of the best, as it gives many options: one can empty via traditional deck pumpouts at marinas, or use the portable mode at RV stops or home. BTW: one of the other advantages of plumbing it in is that the air-vent permanently removes the dangers of 'head-blowouts' on hot days. Previous stock unit that came with the Mac seemed to develop pressure on hot days, becoming a hazard to the unsuspecting user
