Swing Keel Bolts
72Mac22
Sailboat: Venture 2-24
Swing Keel Bolts
Post by 72Mac22 »
Would someone guide me as to the function of these bolts? It appears to me that the lower, larger bolt is the pivot point. The upper right and the upper left are what I don't know. The left is just a hole. Would it be the for the "lock down bolt" ? Thanks.
Muntasel
Re: Swing Keel Bolts
Post by Muntasel »
You pretty much answered your own questions. I'd suggest to dowload the manual of the V22 from the Resources section of this site, it has a pretty good drawing and explanatinson these keel bolts. Good luck! :macm:
ChockFullOnuts22
Sailboat: Venture 2-22
Post by ChockFullOnuts22 »
Ditto. The right bolt, if I remember the literature correctly, holds in a rubber bump-stop that the keel rests against while in the down position.
72Mac22
Post by 72Mac22 »
You're absolutely right. A great explanation was located in the manual section. I had read through it before but forgot it the details. I like the part about not sticking your finger in the hole.
Thanks.
ChockFullOnuts22
72Mac22 wrote:I like the part about not sticking your finger in the hole.
Thanks.
Haha, me too.
