Also, I have a CDI Roller Furler unit which was already installed when I purchased the boat. How difficult is it to replace the steel cable in the CDI Unit?
Thanks;
Chris
Fxwg80hd wrote:Durning the wind storm Baltimore had on Dec 1st, (blowing 50mph and gust up to 70) it broke my forestay and the mast fell. It appears that as the mast fell, the wind pushed it over the side of the boat bending the base plate. I am concerned that the mast may no longer be true (straight), so I'm wondering if anyone knows how I might go about checking this? If it is no longer true, can it be trued up with adjustments on the stays? I am planning on replacing the base plate, stays (just in case they were weakened), one bent spreader, and forestay.
Thanks;
Chris
