Does anyone know of a good UK Mercury dealer / Canada Mercury dealer (Got a friend in Canada )or can anyone advise a similar replacement from another manufacturer, the part no is 825096T01 for mercury.
Unless I'm missing something the solenoid is just a low voltage low amp coil that energizes a plunger to make contact with a low voltage high amp starter current, as long as it is rated for the switched current it should work right .
ta
