Electrical master switch and engine running
simsim
Post by simsim »
It is normal when I turn off the electrical master switch of my boat the engine stop running?
Thanks
Divecoz
Re: Electrical master switch and engine running
Post by Divecoz »
There is a concern , that if you turn the "master " switch to off ""Edit: ooopppsss When then engine is running " you could even destroy you engines charging system...
Hamin' X
Post by Hamin' X »
Some switches have a safety feature that will shut down the engine if they are switched to off when running. As Dive indicated, you can blow the engine alternator if it has no where to charge. Not sure of the type of switch you have, or how it is wired.
Most modern outboards require 12 vdc to run the electronics, and if you remove the battery reference voltage the electronics will shut down as a safety. Also, things like the safety and overheat loops will probably need 12vdc to be enabled.
Divecoz
Post by Divecoz »
Would you list these ? If available for a reasonable cost they might well be of interest to members..
Hamin' X wrote:Some switches have a safety feature that will shut down the engine if they are switched to off when running. As Dive indicated, you can blow the engine alternator if it has no where to charge. Not sure of the type of switch you have, or how it is wired.
Hamin' X
Post by Hamin' X »
Divecoz wrote:Would you list these ? If available for a reasonable cost they might well be of interest to members..
I don't have a complete list Dive, but as an example, there is the Perko 8503.
It has an alternator field disconnect feature, that can be used to interrupt the ignition circuit for outboards. Although not a use in the product description, I have seen it in real-world use. I don't use it personally, as I have an automatic combiner/isolator system.
c130king
Post by c130king »
Just out of curiosity why would you need to turn off your master DC switch while the eingine is running?
Hamin' X
Post by Hamin' X »
There is no reason that I can think of, but it can happen by accident, or through ignorance.
Divecoz
Post by Divecoz »
Agreed.. and thanks for the link on Perko Rich...... For the Love Guys its an additional $17 for a switch that just may.... save you hundreds and ultimately thousands of dollars( depending on the situation.)
Hamin' X wrote:There is no reason that I can think of, but it can happen by accident, or through ignorance.
simsim
Post by simsim »
c130king wrote:Just out of curiosity why would you need to turn off your master DC switch while the eingine is running?
It's by error
Simsim
simsim
Post by simsim »
It's normal, I spoke with the dealer and on a Mercury 60 HP four stroke 2005 EFI (Electronic Fuel Injection) the computer and fire need more electrcial suply thsn jute with normal coil. But my motor has a alternator to recharge the batteries.
Phil M
Post by Phil M »
My Perko battery switch was installed at the base of the companionway ladder just on your left side as you step down. For the first time ever, just last week, I accidently hit the Perko switch with my foot and the switch moved to the OFF position while the engine was running.
Within ten seconds I realized my clumsiness, and turned the switch back to battery 1 position, but the damage had been done. I was afraid to shut off my Honda 50.
But, the only damage turned out to be a couple of fuses in my panel and in my autopilot. The Honda survived the mishap. :|
Phil M :macm:
