This past weekend we were experiencing some problems with the engine -
Saturday we set sail for Antidote on the Chesapeake. Winds died down, so at the Rappahanock River, we turned the engine on and powered around Windmill Point, and up into Little Bay where we anchored at the mouth of Antidote creek. Great anchorage if anyone is ever thinking of a southern Chesapeake trip
Sunday morning we decided to weigh anchor. Starting the engine first, the engine sounded fine. Its first start up with higher RPMs as usual was fine, but about 30 seconds later, when the engine idled down to regular idle speed, the temperature light came on and started beeping. The beep code was 1 second long every 3-5 seconds. Water WAS coming out of the exhaust hole as normal, and I immediately shut down the engine, lifted it to check the cooling water intake and dropped it into the water again. Started engine again, and the same problem occurred.
Later that day after sailing back to port, I tried it again, with the same results. I did not see anything in the Selco manual for this code. Has anyone ever experienced this? Is there any insight anyone can give me? My first thought was impeller, or thermostat, but I'm not real sure since the exhaust water is coming out like it always does, about 1 - 1.5 feet behind the engine. I'm also not sure when the impeller was last replaced. I was planning on replacing this winter but it might be time now.
Any help would be appreciated.
Robert
