Where to put the dinghy?
joesonio
Post by joesonio »
Hey all,
I just bought a 9 foot inflatable. It's a pain in the ass to put it on the bow, but that's what I've been stuck with. My dock Image is as shown. Is there a way to hoist to the boat out of the water from the dock? I've looked at air docks and some other gizmos but they are either too expensive or just too bulky for such a light weight boat. Any ideas?
Re: Where to put the dinghy?
You can't just pull the dinghy out of the water and onto the dock with the painter line? That's what I do. Perhaps I don't understand the question.
aya16
Post by aya16 »
you can pick the dinghy up and place it on the bow, by using your jib/cover line and the winch on the port side. Do it all the time at Catalina. Works great.
make sure you use a pulley attached to the deck.
Mike
mrbillfll
Sailboat: MacGregor 26D
Post by mrbillfll »
try a spinnaker or jib halyard? to a bridle on the dink?
are you lifting it with the engine in place?
joesonio
Post by joesonio »
No engine, so it should be pretty easy. I'll try to the jib halyard. Didn't want to put it on the dock because it's dirty and full of old nails. May put some astroturf on it though. Thanks for the advice!
I have a shackle on the bow lifeline. This allows me to break it so I can drag the dinghy on the deck. It's still a bear, but it makes it easier. I like the halyard idea, might try that next time.
Ixneigh
Post by Ixneigh »
Watch out for those plastic winches doing that :D :wink: :wink:
J/k I think weve beat that horse enough 8)
mrbillfll
Post by mrbillfll »
type of dingy? rollup or rib?
you'll often see powerboats on 'chocks' resting on land. no reason you can't make some for your dingy, and leave it on the dock (private dock?) if they allow that.
just get some 2x6" (or as wide as you need) and cut openings for the bow profile and stern profile, and use a 4x4 as the middle (you want it heavy). and rest the dink in place.
if you plan ahead, maybe you can use the chocks on your bow deck....
ex:
http://www.bixlersmarine.com/assets/ima ... chocks.jpg
http://www.siniada.info/wp-content/uplo ... Chocks.jpg
http://www.ribeye.co.uk/img/access-img/RY_6200.jpg
