FAAbaddog wrote:Here is what we did:
2) 2 full coats of Pettit UltimaSR 60 anti-foulant-- first coat
red (#1036), second coat black (#1038)...
Have you looked at the bottom at all yet? I'd really like to know if you have any barnacles growing with the Ultima SR 60?
We were in the water there almost 2 months and had some very small, under 1/8th inch barnacles on the bottom when we pulled the boat out. It took about 30 minutes to scrape them off back in Utah with a Teflon spatula.
When we go back down I'll be putting a barrier coat on the Endeavour along with bottom paint. It will be in the water probably 6 months max a year, so a lot like a trailered boat. We used Sea Hawk Cukote Biocide Plus on the Mac and I will either put that on the Endeavour or the Ultima SR 60 if it looks like it works better, so would like to know what your bottom looks like when you pull the boat out.
We had some slime at the waterline while down there, but it wiped off in a few minutes with a sponge from the dinghy. No slime further down.
Thanks for any info you can give us,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
