well i guess my perspective on "alot of work " is different .... after having fabricated a mast cap, stuffed my mast with a conduit, wire and foam, re-wired my steaming light with diodes, installed hangars in the portside rear berth to stow the boom and poles, chased down leaks in the anchor locker drain, (had to reglass up there from the V-berth, a real PITA,)
and changed the backstay from the starboard side to the portside, so i could re-hinge the helm seat on the portside to get it out of the way for boarding thru the transom, the process of merely cutting off the ends of the spreaders and re-attaching the tips, and drillinjg two holes for moving a bolt to a slightly higher location on the mast is really minimal work.
The sail is hitting the spreaders before the sheets run into the shroud, and if i can pull the sail in 8 inches more there, its a lot to gain.
Moreover, if the spreaders are 8" shorter over the cabin top when the mast is being lowered or raised, thats alot less interference to watch out for. Risk is minimal if the other sailors who have done it saw no ill effects on structural strength, (its only 2 inches higher on the mast) and the rig can be returned to stock configuration as easily as replacing the two spreaders and moving a bolt back to the original hole. Permanently altering the length of shrouds and messing with a swaging process i have no experience with seems alot more risky.
Do check the Performance and Tuning section on this very same Discussion Board to view the shorten-the-spreaders thread.
And at the same time, thank you for the safety concerns, it's always wise to pause and listen to experienced advice. The same sort of care is taken by most of the Mac owners who have bigger than 50hp motors, 'though the margin of design strength for a motor 20% more powerful, (60hp) doesn't seem to alarm.
I was amazed at the owner who pulled his temporary step pin out, to put in the oem bolt when the mast was up, but some even thought that was not too risky. !!
