O the good old days I lived in SF Bay like 30 years ago and the marine store had all the answers. So now I am stuck. Thanks to this forum there is hope I will get this working!
If the boat is on the trailer and you can run the garden hose down into the tank put it to the bottom of the tank. Then turn the hose on for a minute to fill it and then take it off the spigot and the water will all siphon out. Did this with the bilge of the Endeavour up on stands and it emptied it all except for the last inch.MarkSouth wrote:...In the next day or two I will hook up the maceration pump to the other side of the YValue. It says its self priming so I hope it works! Otherwise I have now filled up the tank with clear water from the garden hose and will not have a way to empty it
