MoTor won't turn over. Ran yesterday. Etec 60
Ixneigh
Post by Ixneigh »
Hi everyone. There was something like this on the board before I think.
I have tilt, beep on key turn. Nothing else. Batteries light lights fine. Ive tried start on dead batteries. Nothing like this I checked the ten amp fuse on the plastic flywheel shroud. Any other fuses?Mean time I shall try rowing the yacht since its flat calm. :D :D
Re: MoTor won't turn over. Ran yesterday. Etec 60
Post by K9Kampers »
Are you in nuetral? Try working the shift handle F-R and back to find N.
Ixneigh
Post by Ixneigh »
Got it. Tried that and thought it was in position. First thing I looked at. Did the full arc of motion and it started. 8)
Bassco66
Location: Hobart.Tasmania.Australia.One Of The 05 Extra Fast Blue Models. "MoonShadow" 50hp e-tec
Post by Bassco66 »
Hi from tassie
I agree with last post, check for neutral. Easy mistake to make. :macm: :D 8)
raycarlson
Post by raycarlson »
first check batteries and connections,your lights can work fine but starter won't crank if your down to like 12.2-3volts, and most important make sure you are using XD-100, i hear it's like a magic potion for ETEC's
bscott
Post by bscott »
Another common problem with E-tec is the throttle cable coming off at the engine and the neutral switch not activated.
Also, BRP does not recommend wing nut battery connections--not sure why but they don't. My engine has started with less than 12v. and with one manual turn of the flywheel.
Bob
:D :D :D :D
Youse just plain NASTY, Ray !!!
:D :D :D
Hugh
Post by Hugh »
And I thought it was just me. The shifter/throttle lever may be stiff when new. We've only been out 2x but finding neutral is tough. I find I have to watch that the movable part of the lever slides down to engage neutral. My second attempt at docking I reversed the motor, shifted into what thought I was in neutral, I jumped out with the stern line. The boat started backwards. :| luckily my wife had secured the bow. I scrambled gracefully back into the cockpit to find neutral.
I hope no one at the ramp noticed....
Hugh
March
Post by March »
Classic.
Did you put it in neutral when you started rowing?
Post by K9Kampers »
Hugh wrote:... The boat started backwards. :| luckily my wife had secured the bow. I scrambled gracefully back into the cockpit to find neutral.
I saw that maneuver on a YouTube vid... was that youuu?!! :D :wink:
