I can’t tell from the photos, but examine the break up close and see if it is equally shiny all the way around. I would expect that under good light and a magnifier you will be able to see an area near the holes where the aluminum is not as shiny. Meaning that the area has been fatiguing for a while.
Was the mast curved gently to one side, or was there a fairly sharp bend at the area of the holes? Meaning that the area was already weakening, and probably from lack of proper rig tensioning.
OK, so there’s an echo in here. You get the idea.
The maximum forces on the mast are a function of the righting moment of the boat, assuming proper rigging. And the righting moment of the boat is pre-determined in its design, so the boat simply heels to relieve the stress. Meaning, the way you were handling the boat at the time of the mast failure was not a function of any negligence on your part!
- Brian.
