Pop Top questions
Sailing Virginia
Sailboat: Venture 2-24
Pop Top questions
Post by Sailing Virginia »
71' Mac / Venture poptop has large holes that bolts go through. My boat has a varity of washers on the inside. The PO taped over holes on the top with a HVAC SILVER TAPE. Does anyone know of replacement washers and or bolts? Any photos showing the set up out there? (I've looked and found very little) Anyone know of a replacement cover for the top, screen or canvas? One's I've seen were custom made...Thanks in advance for your help on these questions.
PNKFLOYD
Re: Pop Top questions
Post by PNKFLOYD »
Sailing Virginia-
There are six 1/4"SS machine screws holding my top down. They have wing nuts inside and three have large rubber washers under the top to space betwwen the top and the cabin roof. I'm going to find an old tire tube to cut out spacers for the other three screws and add a rubber washer and SS flatwasher under the wing nut to tighten the top down again. I'll try to wrap a bread tie around the screw and top rubber washer to keep from losing them every time I pop the top up. Be sure to only hand tighten the wingnuts to keep from cracking the fiberglass.
You could use bronze hardware in fresh water, but salt water will corrode bronze or galvanized steel hardware.
Hope this hepls.
Mike
Sailing Virginia
PNKFLOYD wrote:Sailing Virginia-
Hope this hepls.
Mike
Thanks, I have a bag full of stuff that came with the boat and some it looks like what you described. I'll post some photos of it in the next few days.
PNKFLOYD
Post by PNKFLOYD »
I found some nylon washers that may be better than old tire tube.
This is just one site:
http://www.jamestowndistributors.com/us ... at+Washers
Let me know if you come up with any bright ideas!
Mike
RobertB
Post by RobertB »
Save on shipping and buy the same ones from your local hardware store.
Sailing Virginia
Took a photo of some hardware that came with the boat. The SS bolts / worn out washers must go with the top. Rusty winch cover and handle to the two winches in the cockpit. Will replace them in the near future.
PNKFLOYD
Post by PNKFLOYD »
We seem to have the same type of hardware.
Except, mine is rusted in slightly different places.
If it keeps raining, I may be able to sail off the trailer in my driveway!
Mike
RobertB
Post by RobertB »
PNKFLOYD wrote:We seem to have the same type of hardware.
Mike
Always good to have an alternate form of transportation for the morning commute :)
