Honda B100L DC Output
bmxer
Sailboat: Venture 2-22
Post by bmxer »
I have a B100L Honda outboard and it has an output for charging a battery. The plug came with the motor, you just need to supply the wire. Anyone do this before? Its a weird plug, so I assume that there is a polarity issue.
kadet
Re: Honda B100L DC Output
Post by kadet »
Correct, if it is the same as the 12v plug on a portable generator the vertical pin on yours is positive but this can be easily tested with a voltmeter.
bmxer
Post by bmxer »
Prefect .... thanks
