replacement LED bulbs-1141
sirlandsalot
Post by sirlandsalot »
My old RV has nice little LED bulbs installed in all the 12V dome lights. They are a little bit more money but way cheaper than changing the entire dome light to LED. They also work in the tail lights!
I pulled a few out and replaced the 12V bulbs with them in the 12V dome lights in my :macm: ....They don't work! :? Why would they work on my 12 volt lights in an RV and not on the 12v lights in a mac? let's see somebody answer this one!
Cheers, David
jimbo
Re: replacement LED bulbs-1141
Post by jimbo »
right way around?
Reversed Polarity !!
Highlander wrote:Reversed Polarity !!
Yep. I don't know why, but the lights in the Mac are always wired backwards from what you'd expect in a car or RV, so although incandescent bulbs work fine, when using LED's you need to reverse the polarity.
Tony E
Post by Tony E »
Same thing happened to me but yes switch around the wire and "there is light".... :)
As stated, most likely polarity is backwards. Mac workers didn't have to concern themselves with polarity on incandescent bulbs.
I have found some LEDs that work both directions. One is in my anchor light and I had to install an actual Diode to use it in my reverse polarity mast steaming/anchor scheme.
sirlandsalot
Well! .....you guys sure answer that one easy....had me bafooned! Gotta love this forum.
Happy sailing everyone, tis getting to be the season!
David
