Wiring Diagram
1-Tntimbo
Wiring Diagram
Post by 1-Tntimbo »
I have bone stock 26X I am in process of outfitting.
I want to add a 30 amp shore power system to power 3 or 4 std 110v outlets. The system would include a 2000 watt combo inverter/battery charger, 2 marine battery's (1engine/operating & 1 house)
Where can I find a wiring diagram that shows me the BEST way to hook this all up.
T
Herschel
Re: Wiring Diagram
Post by Herschel »
I am totally out of my area of expertise here, but I did do a quick search on the forum for "wiring diagram: and found this discussion.
http://www.macgregorsailors.com/forum/v ... ng+diagram
1-Tntimbo
Re: Wiring Diagram
Post by 1-Tntimbo »
Thanks, I did not try that. Good info!
Hamin' X
Re: Wiring Diagram
Post by Hamin' X »
Hamin' X
Re: Wiring Diagram
Post by Hamin' X »
1-Tntimbo
Re: Wiring Diagram
Post by 1-Tntimbo »
Thanks for all of this, very helpful and informative.
T
Re: Wiring Diagram
So in summary for those of us with ADD: Does shore power AC neutral tie to DC ground/negative battery terminal?
Hamin' X
Re: Wiring Diagram
Post by Hamin' X »
Grounding; All AC devices must be grounded. The ground and neutral wire are connected together at the dock and must not be connected together on board (except at generators and internally in inverters) The main AC ground bus must be connected to the engine negative terminal or the DC main negative, or the boats DC grounding bus (ABYC E11)
Re: Wiring Diagram
Perfect! Thanks Rich
