Gate Valve Is Hard To Open
dxg4848
Post by dxg4848 »
I had real hard time trying to open gate valve for the first time this spring. The valve was closed in winter. I cleaned it from outside, sprayed it with water and cycled it up and down trying to open. After I got it opened the valve worked fine and I could open and close it with little effort.
I left it closed and next day had similar problem. Should I try lubricating it? What product should I use? Or is there any other way to fix it?
Thanks for your help!
RobertB
Re: Gate Valve Is Hard To Open
Post by RobertB »
Silicone spray would be good. WD40 will do in a pinch since it does not adversely affect plastics (legend is that it is made from fish oil - not petroleum).
RobertB wrote:Silicone spray would be good.
I've used electric bulb grease which contains silicone. Wear a rubber glove, as that stuff is hard to clean off.
dxg4848
Post by dxg4848 »
RobertB wrote:Silicone spray would be good. WD40 will do in a pinch since it does not adversely affect plastics (legend is that it is made from fish oil - not petroleum).
Robert, thanks for reply. After thinking more about it I went ahead and purchased new valve from BWY. They have it in stock and promised to ship today. My boat is still on the trailer and I was planning to put it in marina in about two weeks. So I have enough time to replace it and not worry about it. The valve I have now came with the boat and is 5 years old.
seahouse
Post by seahouse »
dxg - you might want to take a look at (take apart?) the old gate valve and see what the problem is after you have it off. You might be able to prevent it from happening in the future by doing something simple? Five years doesn't seem like much for it. Or report back what you find so someone else might be able to avoid the problem in the future?
- Brian. :wink:
ps. lake ice gone soon!!!
EZ
Location: 2004 26M "Stray Monkey", with Etec 50, SF Bay, CA
Post by EZ »
Every year I lube the gate valve with Evinrude grease. The grease is designed for marine use and won't wash off easily from the movement of the water against the valve as you sail/power.
My boat is a 2004 model and I have yet to change the gate valve.
dxg4848
Post by dxg4848 »
EZ wrote:Every year I lube the gate valve with Evinrude grease. The grease is designed for marine use and won't wash off easily from the movement of the water against the valve as you sail/power.
Evinrude Triple Guard grease worked great! I already bought replacement valve, but may not install it right away now. I'll keep it as a spare. BWY had it in stock and shipped the same day. It is not the first time I buy from them and they are great!
Hamin' X
Post by Hamin' X »
Mine is a 2001 and I spray it with PAM once a year. Works a treat!
andyman2000
Post by andyman2000 »
Nothing against BWY, I order lots of stuff from them. But if your in a pinch for a gatevalve and need 2 day delivery for free try amazon. Assuming you have prime.
$33 and free 2 day shipping with prime.
http://www.amazon.com/gp/product/B00B95 ... UTF8&psc=1
Gotta love the Amazon prime shipping. And for $4.00 they'll overnight anything not matter how much it weighs. We ordered a trampoline. It came in 2 days in 3 heavy boxes....for free shipping.
My gate valve was stiff. Shot it with some silicone and it was happy again.
Camping World has them in stock if there's one near you.
