Whats the top end of your Mac when motoring?
moonie
Post by moonie »
I managed to reach 14.9mph with a full ballast tank and my 50 Etec in a Force 3. I would like to find out if a higher topend is possible with the 50hp.
baldbaby2000
Post by baldbaby2000 »
With my 40hp Tohatsu I can hit almost 14 mph without ballast.
Rolf
Post by Rolf »
I've done 20 knots (about 24 mph) ballast full with my Tohatsu TLDI 90 horse.
Rolf
KRV
Post by KRV »
I cruise at 17 Knots and top out at 20. 70 HP SUZUKI (04 M) with empty ballast.
Norm
Location: Fiddletown, Ca. 2002X "FriendShip" Johnson 50hp 4-stroke
Post by Norm »
20.1mph 26X empty ballast 50hp Johnson 4-stroke, 11.75" 10 pitch prop. No wind, calm lake.
Tom Root
Location: Annville, PA. s/v-Great White, MacX4787A202,'09 Suzuki DF-50
Post by Tom Root »
18 MPH top with several hundred pounds of gear, 2 people. One person mostly stipped but mast still on I recently maintained 20 MPH, Ocean, 1-2 foot mini swells, no ballast, Suzuki-50, 10X12 piranha modular composite prop that has been shaved a bit for speed. Love this prop, and would highly recommend it to anyone, so far it has given me many hundreds of miles of great service. Also have two spares....Justin Case! 8) http://www.piranha.com/propellers.php
I am certain, if I remove the mast and extra anchors/chain rhodes etc. I can easily see 22+ MPH on this boat!
Harrison
Post by Harrison »
Light gear, no mast, 3 adults, no balast, 5400 feet above sea level, Merc 60 BF, calm lake, 5700 RPM, = 18 MPH.
TampaMac
Post by TampaMac »
No mast, no rigging, 60 hp Mercury 4 stroke.
I can't remember the exact figure but it was about 23 mph.
Steve
Post by Steve »
I've topped out at 19 w/o full ballast, 14 w/ full ballast, Yamaha 50/4 stroke. Also have a 26 gal. Plastimo water bag under the fore settee at table which I'm sure effects my top end too! :)
:macx:
Ben
Post by Ben »
No Ballast, Mast up just under 20mph at 6200rpm on Johnson 50 4 stroke.
Tom Spohn
Post by Tom Spohn »
Moved the boat today. '04M with 70 HP Suzuki. Two adults, one dog, medium gear, no ballast, topped out at 20.3 mph at 5150 rpm.
KRV What is your max rpm for 20mph and cruise at 17mph?
awolfe
Post by awolfe »
Moved our boat to her new slip, about 40 miles away. Hit a top speed (w/o ballast, mast down)of 65mph, averaged abouit 55mph - Ford V8. 8)
Andy26M
about 18
Post by Andy26M »
2004 26M, no ballast, one person (200#), couple hundred pounds of gear, 20 gallons of water under the V-berth, 50 HP Honda, 24 gallons fuel in the cockpit, mast up, ablative bottom paint:
w.o.t. = 17 mph
= 18 mph if you get rid of the water forward and half the gas
In heavier seas I pump out the V-berth water if I want to go "fast" because it holds the bow down, which is nice for seakeeping but adds more spray in the cockpit.
I'm figuring that the bottom paint (very rough chalky surface) is costing me about 2 mph, but seaweed and barnacles would be even slower...
- AndyS
bobmonroe
Location: winter-Vero Beach, FL. Summer- Saluda. NC '99 26X, 50 Etec, Chevvy Tahoe
Post by bobmonroe »
While waiting for a 14Dx11p from WM, for my 50ETEC, I decided to try a 3 blade SS, 13Dx17P off my 70 Johnson 17' runabout. The boat was empty, except for 2 adults, 2 -6 packs to keep the waters smooth, and about 12 gal of gas. We did 22.5 statute at 5100 rpm. Later found a new 3 blade alum 14Dx13P at a flea mkt, the boat did 21 mph statute at 5700 rpm. I put 10 gal of water in the bow. I think I need some way to trim the bow down without adding wt. up there. I haven't researched the wedge solution.
Andy26M
engine mount trim
Post by Andy26M »
Bobmonroe -
You can effect the trim of the boat to some extent by moving the long pin in the engine mount that the engine sits down on when lowered. There should be a range of holes there in an arc. Putting the pin in a hole closer to the transom should help push the nose down a bit, and vice versa.
- AndyS
Locked
