Yeah, I can imagine. It should take ten minutes. Max.kevinnem wrote:the mast is bent like a bananna toward the back when we are done. I don't like it at all, I hate it so much . it gets in the way of the joy we should have.
Sounds like you have the backstay connected while raising the mast - a big no-no. Also sounds like the shrouds may be too tight.
Go to the "Resources" tab at the top of this page, and download the manual for the vintage of your boat. Adjust the mast per the procedure (by the numbers - don't cheat), then disconnect the backstay to lower and raise the mast. The backstay isn't very taught when it's adjusted correctly, but I have a turnbuckle in mine anyway, so I don't even have to disconnect it. A Johnson lever would be even better, as all you do is flip it and stick the pin in.
Use the MRS to put extra forward pull on the mast to pin the forestay, then when you slacken it, the rigging should be just right. It's stretchy, like all wire rope is, so overtensioning it in order to pin the forestay won't hurt it as long as you don't get carried away.
I do this by myself, by the way, with zero assistance from anyone, even if someone else is present. Another person really is no help.
See comments above about setting up the rig per the MacGregor manual. It should be pretty easy and painless, especially with a MRS. If you have the help available, there's no need to crank the winch on the cabin roof. Use it as a ratcheting unpowered capstan (take a few turns around it so you can hold the line with the mast load on it easily), and have someone push the mast up while you pull with both hands. Once it's up a bit, it gets easier, and you should be able to just hand-over-hand the MRS line until it's all the way up. Cleat it off with both the jamb cleat, and cleat the tail to the stern cleat (slack, but positively cleated) if you have to let go of it for any reason.kevinnem wrote:We are at the point where the women just will not want to go anywhere with teh boat, because only of the mast.[/quote
Well, that's not good.Get it set up correctly, and it will be easy.
kevinnem wrote:is my rake to far back .. should I loosen the sides. (top or bottom). I don't know how to set up the standing rigging, but my world is not anything like what you guys are talking about now .. my world is horrible crappy painful hours of getting the mast up.
You DO have baby stays on that mast while raising it, don't you?
