I'm thinking to buy an Asymmetrical Spinnaker and sock used one for a
don't have a lot of $ for that
do you thing it worth the expense
did somebody know where I can find one not to expensive
thanks
Jean-Francois
+1mastreb wrote:I will say that I think the downwind performance of a Mac with the stock 150 roller genny and mainsail is pretty damned good, especially if you pull up all boards and leave 0 or 1 rudder down only. It's downwind performance is equal to or better than its performance on any other point of sail.
MUCH better downwind than a keelboat, which must have a spin to be efficient downwind. On a Mac I think a spinnaker is pretty much cosmetic, or needed only if you fly a hank-on 110% as your headsail.
That's why I use the spinnaker. I don't use the 150. Blocks too much of my view, the boat handles better with the smaller head sail, and it's like new because the PO never used it.kadet wrote:I only have the spin because I went from a 150 to 110 jib to save sail changes on the roller furler. The performance difference is minimal and then only in light winds between the 150 and the spin.
I have used a similar paint roller extension pole.vizwhiz wrote:Would something like this work? We don't have really large or heavy sails...
http://m.lowes.com/pd/Wooster-8-Feet--1 ... le/1054249
12 ft telescopic whisker pole from Forespar. Long enough for the 110, but too short for the genoa. http://www.westmarine.com/buy/forespar- ... -l--111179 Spike or latch versions. But you need to mount a ring on the mast.dlandersson wrote:What can I buy ready-made?
