I changed to a 110 jib and the spin for down wind. I got rid of the Genoa as it does all but it does not do it all well. Since then, I spend a lot of time at haul speed in light wind.
I would like to do a set up with the Genoa and Jib like Highlander because I love using all sails and enjoy the experience of learning each one, but I think the jib/spin is best for the
When I was shopping for the sail, I did find a used sail store on-line in California that had excellent stock of every type of used sail you can imagine. Unfortunately I can not remember the name. I saw several also pass through Ebay. You do not need the exact dimensions of the stock sail...just something roughly close, but preferably not much bigger. Mine is a tad larger than the stock, so I made sure the mast hound was as low as I could go without interfering with the jib mast hound. I made a cheap (under 50 bucks) pulpit which is not necessary but is a great improvement. My tack line is also run aft up the port side of the boat so I can REALLY play with hanging the sail out there...super fun.
