The new axle is a "dead" axle , no brakes .
Haven't loaded the Gypsy on her yet , but looking forward to it .
sailboatmike wrote:Im not sure how it works in the USA and Canada but in Australia adding a second axle would only reduce the load carrying capacity of the trailer (AGM) as your adding weight, that is of course unless they re rate the trailer for you.
My X tows like its on rails at 110Kph (65mph) on the standard single axle trailer, generally if the trailer is moving around its because of poor weight distribution, incorrect height of the tow ball or incorrect tow ball weight
Because the empty trailer now weighs more, but it still has the same gross weight rating (3500 lb) from the factory, on the nameplate. So adding another couple hundred pounds makes it a couple of hundred pounds more overloaded, because they're virtually always overloaded with anything more than a box of Kleenex on the boat to start with.Three Gypsies wrote:Not sure how adding a second axle can reduce my load carrying capacity .
That's a 3500 lb axle under there, and I personally think small trailer axles are optimistically rated to start with, so I'm quite happy the PO's added another 3500 lb axle to mine.Three Gypsies wrote:I was afraid that Her increased weight would overload the trailer and possibly break the axle .
It's worse than that. My marketing sheet says the boat weighs 2350 lb, and the trailer 710 lb. That's 3060 lb. And that's without engine. And probably without headsail. Or fuel tanks. Or mast raising system. Or just about anything that makes the boat useful.Three Gypsies wrote:My plate says 3500 lbs , I believe the empty , dry , boat weighs about 3,000 lbs so that left only 500 lbs for gear . Not much for liveaboards.
