stereo recommendations?
David Mellon
Re: stereo recommendations?
Post by David Mellon »
Here is what I came up with. My speaker placement has proved to be excellent, versatile and really quite simple to install.
http://www.macgregorsailors.com/modt/index.php?view=691
Bilgemaster
Post by Bilgemaster »
CliffsNotes version please :P :D
Gotcha! Executive Summary:
I got this cheap one 'cause I like to plug stuff in:
Sounds good. Hope it works better that the last one, and Soylent Green is people!
Bilgemaster
David Mellon wrote:Here is what I came up with. My speaker placement has proved to be excellent, versatile and really quite simple to install.
That's an elegant setup. Well done!
Curwen
Sailboat: MacGregor 26D
Post by Curwen »
Hello,
Anybody given any thoughts on using a bluetooth speaker? I've seen several waterproof bluetooth speakers and thought the might be a useful solution. I haven't hit any of the stores to see if there is decent sound.
Curwen
Curwen wrote:Hello,
Curwen
That might be a good solution. I installed a bluetooth receiver to my built in stereo. I do have a hardwired 3.5mm plug in the cockpit to connect iPhone etc.
I haven't used the bluetooth adapter since plugging it in, but it's simple and works.
http://www.amazon.com/Mpow-Streambot-Bl ... h+receiver
We have The Amazon Echo device. Fantastic sound from a small speaker and the the automation features are from the Jetsons. This thing is really cool.
The Amazon Tap just came out and seems to be a portable version of it. It it's anything like the Echo, it will be awesome. I may get one for the boat.
http://www.amazon.com/Amazon-PW3840KL-T ... ywords=tap
grady
Post by grady »
Curwen wrote:Hello,
Curwen
Yes there are some Bluetooth speakers that have good sound. You are probably looking at around $150 range. I have the Solemate and it realy has good sound. Battery life is good It will play all day in my office at a low volume with no problem. At max volume I think I get around 7 hours out of it.
http://www.jabra.com/music/wireless-spe ... a-solemate
I don't know about the rest of you, but I also like to play music while motoring. This means having a speaker which can handle a greater volume with reasonable distortion to the sound. What sounds good in an office environment, may not suffice on the water with the outboard and apparent wind doing their thing.
grady
Post by grady »
NiceAft wrote:I don't know about the rest of you, but I also like to play music while motoring. This means having a speaker which can handle a greater volume with reasonable distortion to the sound. What sounds good in an office environment, may not suffice on the water with the outboard and apparent wind doing their thing.
If you want to hear it over your outboard I do not think any portable speaker is an option.
Grady,
You understand my point.
I was just making certain the before making that purchase, be certain that the speakers satisfy all of your requirements.
yukonbob
Post by yukonbob »
For motoring I use headphones. Nothing will compete with them especially noise cancelling ones. Even if you throw a 2000w system in you'll still hear the drone of the outboard. While at anchor it is surprising how little sound you need, especially after spending a couple days sailing and sleeping on the hook, everything gets louder.
millcity
Post by millcity »
