Very nice work. Varnish or urethane?
Head is in the port hull bow, closet behind, basic for now. Old pic before a door, you can kinda see the frame on the left. Was going to install a composting head, but have always been fine with a bucket system similar to sumners so still using that for now. No plans for indoor shower.is there a head & shower or is that still on the finishing plans or did I just miss it !
Will have to take one. Not sure if the hasp is Mayo approved. It still has the original door knob and skeleton key lock. First day I brought the huge skeleton key home and said "can't loose this", have not seen it sinceNo build thread is complete without a closeup of your gate hasp.
Yup, I debated that. Another iroquois owner refit did similar process with a good write up.He essentially stained a piece of birch plywood, then routed the "stripes" (just deep enough to get below the stain) and then a couple of coats of "bar top" epoxy. Then cut to shape and viola! Instant teak decking!
The floor I am trying is 7/16 solid teak from diamond tropicals. Time will tell how it holds up, I basically just tried what I thought may work. Tongue and groove assembled with epoxy for adhesive, then grooves caulked with teak deck caulking, sanded, then epoxy coated both sides. After the epoxy went a couple coats of varnish for UV protection, then several coats of floor polyeurathane for hardness.Can you teach me how to build a floor like that or tell me what internet site or book I should read to do that? I think that floor would look great in 'boat'.
"epoxy coated both sides. After the epoxy went a couple coats of varnish for UV protection, then several coats of floor polyeurathane for hardness. "
From my understanding oil based spar varnish and polyeurathane are compatible. No trick to it, Each was allowed to dry and everything seemed to go on fine. I don't know if its normal to use both or all three. I just went that way because I knew the epoxy would yellow from UV, the spar varnish would prevent that, and poly would prevent damage to the spar.Whoa, is that normal? Your way ahead of my skills - I did not even know you could use urethane over varnish. That's a great idea - I know that the varnish alone would be too soft - but would it work with just urethane?
I have never tried to mix the two - is there a trick?
Yup, it was. Replaced it with a glassed in divider & teak cover at the cabin entry right below the doors.trip step is what keeps the water out of the cabin
