The RayMarine tiller drive and brain are made in Hungary. The p70 heads are made in China.sailboatmike wrote:But the Raymarine stuff breaks all the time, I know my ST50 wind unit has had 2 wind senders on it before the PO gave up, probably from frustration and empty pockets, lost of the Raymarine stuff is now made in Asia, just like every other brand
I don’t know about the RayMarine wind sensor because I did not get one – why would I? They don’t have one for a rotating mast! If you want a rotating mast sensor from RayMarine they will send you to one of their subsidiaries called TAC-TACK and that's a solar unit and all the problems of wireless associated with that.
I got the Pegasus unit, but really, I don’t expect any of these sensor units to last a real long time if you’re going to leave them up in the air 24/7 in the weather. None of them will last more than 5 or 6 years in constant use. They are “wear items” (and a real pain in the ass to replace if your slipped) and another reason why I did not want a solar panel and batteries up on the mast. Removing the sensor when not on the water helps (also a REAL pain in the ASS!). Otherwise, they are all going to wear out pretty fast with only one exception:
Like I said in a previous post – if you want a really good sensor up on your mast that is the most accurate and bulletproof long life that will last a LONG time you need to go with a ultrasonic sensor – they have no moving parts – they are far superior. If I could get one for a rotating mast that was my first choice – but no one makes one. I tried and tried to get someone to make a unit that would work with an ultrasonic sensor but no one really wanted to do it.
So just get any plastic cup spinner and wind vane and expect them to wear out – just figure on replacing them after every 5 years of continuous use. Anything with moving parts is not going to last.
