Hi BOAT, many thanks, I'm a bit lazy and only really post on something that affects me; will try to keep in touch more.
1. Ignoring the mast rotation works for me BUT not for all, e.g. if you want the True Wind deduced for live route planning.
2. Multiplexing, in this context, relates to the streaming of NMEA0183 data. The NMEA0183 is multi-talker/single-listener thing. If you subject a listener to more than one talker you get the likelihood that the sentences get garbled/mixed and thus become indecipherable to the listener. A multiplexer (somehow) manages to recognise proper sentences, mixed up though they may be, re-assembles them and then transmits them discretely, in a single coherent stream to however many listeners (usually a max of 4) there may be connected.
The Quark-elec QK-A024 (AIS device) does this and much more.
3. I used a NASA Clipper Tactical Wind sensor at the masthead. It outputs a NMEA0183 "MWV" sentence and needs 3 wires - although, if you already have power (it needs 12v, 9mA) at the masthead, you may get way with just the single NMEA0183 wire (if that's all you have).
4. Yes AIS is great. I got it for my Falmouth to Scilly trip as I knew I would be crossing the Lands End Traffic Separation Scheme twice in the dark. I've been surprised at quite how many yachts, often small ones, are transmitting AIS data.
5. The Quark-elec site is at -
https://www.quark-elec.com/product-category/marine/.
As you can see, the QK-A024:
a) Receives AIS data
b) Receives NMEA data (I take a stream from my plotter (it also has a multiplexer) as this contains all the plotter's GPS data plus anything else I've fed it, e.g. sonar data
c) Multiplexes incoming NMEA data (as mentioned)
d) Has an internal wi-fi access point that can be used by up to 4 iDevices simultaneously.
e) The multiplexed NMEA0183 stream is then available as a direct NMEA0183 connection OR via the wi-fi
f) Also outputs NMEA data via USB and RS422 for your laptop etc.
g) Oh, and it receives AIS data on the two channels simultaneously, unlike some that hop.
NB note that you may need their Garmin Bridge product if connecting the NMEA out to a Garmin plotter, as I did. It cost £15.59
To answer your question about getting AIS data on iDevices and your chart-plotter, as you can see thats a normal job of the unit. It's done simultaneously so you get AIS data, in useful form, along with visual and audible alerts, both upstairs and downstairs.
Like any NMEA0183 installation there is often some juggling needed in the wiring department. A common manufacturer's reply to a technical query is "try swapping the "+" & "-" wires and see if that helps. It's not so much "plug and play", more like "suck it and see"
But once it's working…..
The only downside is that you have to tailor your alerts thoughtfully. You will find yourself at the mast, getting on with whatever and something will start bleeping. You'll be wondering; is that??:
1. Shallow water alarm,
2. Low battery alert,
3. Anchor drag alarm,
4. Dangerous AIS target
5. Autopilot ram motor about to burn out.
6. Engine overheat
