New winch for 2007 Al trailer
John Christian
Location: 2007 26M "Pamela Jean" White Hull#1862, Suzkuki DF 70, Brest Bay Marina, Lake Erie
Post by John Christian »
Anyone know the capacity of the oem winch? Im looking at 1 that matches exsiating bolt pattern thats rated at 2500 lbs. That seems sufficient but i thought I would ask the experts before ordering.
kurz
Re: New winch for 2007 Al trailer
Post by kurz »
I find the stock trailer winch is to small.
So I graded up with 1050kg 2gear winch, cheap stile.
Whats the problem with drilling a new whole?
John Christian
1050 kg sounds comparable to 2500 lbs, and yes double tooth.
Seems like an upgrade over original and no drilling
My 1999 OEM steel :macx: trailer has a Shelby 5404 single-speed winch, which is 1200 lb [545 kg] rated. Seems plenty strong enough for my boat, but it's not made any more, so there's that. :|
I replaced my winch with a Fulton F2. Now I have a 2005 steel trailer, but I am sure you can find out if there is a different configuration of mounting screws.
Post by Jimmyt »
Beautiful winch Ray!
kurz
Post by kurz »
If you have the stock trailer with the ledder watch the the crank is at the right side.
I didnt watch this during ordering so I couldn mount it.
Had lock becouse I could change all gears so the crank looked at the right side finally
JCPH3
Post by JCPH3 »
kurz wrote: Wed Aug 21, 2019 11:37 pm If you have the stock trailer with the ledder watch the the crank is at the right side.
Good tip, my ladder is on the port side so the one i originally looked at wouldnt have worked. Thx
