Wind Song (26X) repairs and mods log
hart
Post by hart »
So I’ve got the new trailer under Wind Song, thread located here: viewtopic.php?f=11&t=27544
I’ve got a thread going on the outboard swap here: viewtopic.php?f=8&t=27551
I felt it is a big enough job it deserves it’s own thread but mods if you disagree feel free to merge it here.
I need to start making a list of needed repairs, as well as wanted repairs and maybe “wouldn’t it be nice” mods. I’ll use this thread to document this list as well as show my journey on tackling it.
Pictures incoming. Lots and lots of pictures.
Here’s the starting point:
See the pile of brush? See the stump? Yeah, the boat basically had a tree growing into it.
Moving on. She’s cleaner now:
I’ll hit her with appropriate cleaners, and some wax with rubbing compound. At first I thought I’d compound separately but the oxidation isn’t nearly as bad as I had feared. I guess all that filth formed a protective layer.
More pics -
The hatch sliders are pretty nasty. I might be able to sand them and get a little more life but since I need to pull them and butyl tape under them anyway I’ll probably just go ahead and replace.
While I’m at it I’ll probably put Velcro under the hatch. It’s one of those mods I wanted to do but never got around to.
The companionway sliders are too far gone to even think about saving.
My debate here is plastic again or teak. A “would like to” on my list is to make a three board companionway hatch out of teak. If I end up doing that I’ll probably use teak rails. I might make it out of lexan though. I’m torn.
The handle is toast. I’ll replace it.
The hatch also has water in it I can’t seem to get out. It has had it for years. I might cut out that botched repair, dry it out and reseal. If I’m feeling froggy one day.
All the lines will need to be replaced:
No picture of the mast yet but the lines are in about the same condition.
I like black double braid. I’ll probably use that again.
One of the bow windows is cracked and leaks:
I know ultimately it needs to be replaced. But short term I’m thinking I might try getting that stuff motorcyclists use to repair their lexan windshields.
Two of the side ports have this white stuff on them:
Pressure washing didn’t get it off. Knowing it’s lexan I’m hesitant to go crazy with cleaners. I might see if either Plexus or perhaps even vinegar cuts it.
The mast support pole is stuck:
I bet I’ve emptied half a can of PB Blaster down it with no luck. I think the best option is to remove the mount from the pedestal and apply heat and force.
The gel coat has worn through in two notable spots. Here is the sliding hatch:
There is a similar looking place on one of the cockpit benches. I’m really not sure how I’m going to fix that. I don’t really want to paint the nonskid as most of it is ok. It’s just these two places and it would drive me crazy if it doesn’t match. I’m still researching and open to suggestions.
The original owner made this back deck:
And boy I loved having it. It’s now rotten. I’ll make a new one for sure later in the restoration. I’m debating what wood to use. Thinking either teak or mahogany. I might do strips instead of a solid piece though.
The original owner also made and installed this arch:
He intended for it to be remade out of aluminum or stainless but he never did it. I never did either as it held up well. I’ll have to play with it and see if it’s still structurally sound. Yes, I’d like to redo it eventually, but the boat bucks are adding up fast.
Both rudders need a little gel coat love:
I’m thinking I might just paint the tips though since they are gonna wear again anyway.
While the hatch handle is rough, these teak steps I made for the boarding ladder have held up well:
A little sanding, some brightener, and some oil and they should look great. Need to get new tips for the ladder.
I don’t have pictures of the following yet but the shopping list is getting long. I need to replace the standing rigging as it’s the original. Need two new batteries. The anchor light needs to be replaced and I already have a new led bow light to install.
I think that about covers the exterior. Lots to do on the interior but I’ll take pictures and detail that in a later post.
Re: Wind Song (26X) repairs and mods log
Looking forward to your posts. You have come a long way in a short time.
Are you sure this is Gelcoat issue? Looks like some stubborn grime/mildew. I would bleach this heavily first to be sure.
I'm a big fand of Mary Kate On&Off. It melts away stuff like magic.
hart
Post by hart »
It feels different under foot than the rest of the nonskid but maybe you are right. I’ll try it and see. Thanks Russ.
hart
Post by hart »
No real news to report, been busy working on house projects.
1. I have started sail shopping, or rather window shopping. I won’t be able to buy for a while but have been looking at prices and options. Holy sticker shock Batman.
2. My girlfriend’s son was playing on the boat and nearly dropped the swing keel. Which reminded me I haven’t put a support on the trailer for it yet. Need to do that.
3. Final thought: Might be a while before I can work on the hull. I’m thinking I might use some orpine wash and wax next just to get some basic protection on the fiberglass for now.
Jimmyt
Post by Jimmyt »
Some sort of keel support would be a good idea. The M trailer has a cable that runs across under the dagger - presumably to catch it if the line gets loose. Unfortunately, it doesn't softly nudge it in if you accidentally leave the board down a tad when loading...
Just getting your head around what you need to do and pricing out alternatives is still progress. That way you don't waste those boat bucks!
hart
Post by hart »
I asked the boys what they want to do today. They said clean the boat! Who am I to argue?
Making progress.
The cushions are in much better shape than I thought originally. We’ll wash them up and see how they look.
Jimmyt
Post by Jimmyt »
Wow! Great kids! :wink:
hart
Post by hart »
They were awesome!
More pics. Here is what it looked like a couple weeks ago:
And today:
Water, lots of pine sol and scrub brushes. We hosed everything, scrubbed a section, rinsed, used the shopvac to suck the water out. And moved aft. Repeat. They boys were a huge help.
The caulked liner joint is almost black. Gotta get some sterner stuff after that mildew.
Still have to do the head and the aft berth. But the rest is clean and nice smelling again.
Jimmyt
Post by Jimmyt »
Huge Progress! Hard to believe it's the same boat!
Dougiestyle
Post by Dougiestyle »
Great job!
hart
Post by hart »
Thanks guys. We’re making progress for sure. I’m hopeful we can at least use her as a motor boat in June for the annual Beer Cruise in Pensacola and meet up for a day or two.
Be Free
Post by Be Free »
It's been a while since I worked on it, but as I recall the holder for the mast support is held in by the machine screws you see on the top and a single long bolt near the bottom that goes all the way through the tube. That bolt is what the support sits on when it is in the tube. You will probably have an easier time working on it if you take the whole thing out and get it on the bench. Once the long bolt is out you can try moving it up and down to try to loosen the rust. It also gives you another hole to squirt the PB Blaster in to work it from the other end.
Good luck.
hart
Post by hart »
Thanks for your thoughts. I think you are right. The previous owner added an extension to the lower end of the mast support as well. I don’t recall what it’s made of, but I suspect I have dissimilar metals compounding the problem. I’ll share pictures when I get it off. Maybe you guys will have some inspiration for me.
adudinsk
Post by adudinsk »
For heavy grime, consider using POR Marine Clean.
It is fantastic stuff.. any auto body part shop will sell it. (cnc.. cross canada..etc). Aluminum rim dust just runs off .. would do a fantastic job on the deck!
https://www.por15.com/POR-15-Cleaner-Degreaser
in general www.por15.com has great rust proof paints.. and many great products
For the plexi, I use Novus 3 for heavy scratches.. then follow with NOVUS 2.. to get down to fine scratches.. then Novus 1 for a final polish (this is more like a light liquid wax)
Again many auto body part stores have NOVUS,... so do many marine stores.
AD
adudinsk
Post by adudinsk »
For dissimilar metals, (like in all the front load washing machines) the solution is Por-15 epoxy paint. Paints on easy.. no mixing.. and is the "solution" everyone uses when your aluminum washing machine mount and stainless steel drum rot out.
I use it for tons of projects (only Black/Silver/Clear are avail.. as pigments will let water in) DO NOT use Krylon etc.. not great rust proofing.. \
1) Marine Clean the metal
2) Wet with Metal Ready (coates with Zinc ) for 15 min..
3) Dry 100% and paint with Por 15
https://www.por15.com/POR-15-3-Step-Stop-Rust-System
Its like Bakelite when done.. you will never scratch it with a set of keys...
AWESOME stuff
AD
