Steve wrote:
Are these specs good?
Sounds good to me... these batteries are just a little bit larger than my Group 31 AGMs, but mine are 100ah.
Is it pretty easy to figure out how many hours a device, such as a laptop, or port. tv, will run given this many amp hours?
Very easy, assuming the devices will run off of DC (if you're using an inverter to provide AC, I think it gets a little more complicated).
Suppose you have light that draws 2 amps. In one hour, you'll consume 2ah. So, theoretically, you could run this light for about 62 hours on one of your batteries. However, because it is strongly recommended that you not deeply discharge these batteries, they say you should only discharge them to about 50%. So, your 125ah batteries are effectively just 62ah (usable) each.
It's fairly easy to create a spreadsheet for creating a "budget" of projected power usage within a given time period... enter each device, its amp draw, and estimated time that it will be used. Multiply amps x time for each, then sum that column for total usage.
Also, if you don't already have one, consider buying a battery monitor such as the Link 10 (if your batteries will be tied together as one large bank), or the Link 20 (if they'll kept separate, with a switch to use each as needed). It is literally the closest thing you can buy to a "fuel gauge" for your batteries. One great feature is that you can set it to consider the 50% discharge level to be "empty" when calculating time remaining and displaying battery status via the LED bar graph. So, when the battery monitor tells you the battery is depleted, it's really only halfway discharged (which is what you should consider empty anyway).
Once you have one of these, you can also use to more precisely figure out what each of your devices draws.
--Mike
