BOAT wrote: ↑Tue Mar 31, 2020 6:32 am
Yes, your furler is the Mike Inmon furler.
In that picture if you let out some mainsheet the sail would have been much easier to raise (or lower).
Do your stanchions have sliders or something?? What's that black thing on them?
I want everyone to notice the huge size of the topping lift in that picture
*You forgot to take the noodles off your spreaders)
No I never mentioned that you need to be on deck to use it - when I used it I did everything from the cockpit working two lines at the same time very much like a genoa furler. I am still very curious about that harken flux capacitor you seem to be messing around with a lot.
What I did say was that you were leaving the boom and sail on the deck when TRAILERING and STORING. Most of us can not do that but I do agree it would be a lot more convenient if we could.
(Who is taking the picture?)
I think it's probably the best furler your going to find for a MAC mainsail. The bolt rope is the best feature.
I really miss the performance of a bolted main and I am considering buying a second main with no slugs and no foot. I think a bolted footless main also might be easier to handle for raising and lowering the main because the position of the boom is irrelevant when the outhaul is released.
By the way - does that setup have an outhaul??
Thanks. I thought it probably was an Inmon furler.
Actually, I may have been trying to take some belly out - which also would have been easier without all of that wind pressure on it. Whatever I was doing, I wanted a closeup view of it.
The port stanchion has a black ball bungee on it that holds my cockpit lifeline when I'm not using it (which I wasn't).
Don't judge a man on the size of his topping lift. Came that way from the PO. Hasn't made it to the top of the list yet...
Yes (actually pipe insulation); and when we ran upriver to dump the ballast and let the Etec take a deep breath, one of those came off. Fortunately my daughter saw it and we were able to gather it back up. Hate littering.
I know you said it could be done from the cockpit - I just figured you were gonna give me a wire brushing over being on deck.
My.baby daughter, now 23, took the picture. It is the first time we've gotten to go without a lot of other folks. Her mom was working. Love all three of my daughters, and it's nice to get to spend a little time getting to know what kind of adults they're turning into. Hard for me to do in a crowd. If the weather stays good, may try again soon. Pollen is really bad though right now.
I generally like it. If the roll didn't migrate forward as you furl, it would be fine with me. Fixing that may require a redesign. It seems the topping lift has to be used to raise the back of the boom to get the guide to pull the bolt rope away from the front of the drum. But, the bracket at the front of the drum won't allow much boom movement before it hits the mast. Probably just my technique... I'm still learning it. Basically only use it once to put it up, then 5-9 hours later to take it down. That day I used it three times, since we started off reefed.
Not too sure about a footless main, but have been accused of being a brainless captain.
Yes, there is a line in the outhaul position, but it is not easily adjustable. I'll try to get a pic if you would like one.
The front end of the leisure furl is the direction I'm leaning. If the rear is made such that the drum can slide fore and aft in the boom, then it's exactly what I'm thinking needs to be done. Plus, it is way more stylish... as you can see from the pic, I'm all about style...
Thanks for not picking on me too bad. Hope you're staying healthy. Since schools are out, and the youngest is a teacher, she's staying with us for a bit. We're all good so far. The other two are in health care related jobs in another city a bit north. Little more widespread up there. I think the oldest may have it now (her test results are not back yet). She doesn't have fever any more, but still doesn't feel very good. She's about 8 days in. One of the kids is sick, but has not been tested. Middle daughter is good so far.
