1) Mounting the batteries in port and starboard compartments (under sink, under aft dinette seat.)
built and glassed in trays to hold them level
2) Changed the oil/fuel filter/ all internal and external anodes
3) Changed lower end oil, hand water, so I 100% replaced all seals on the prop (outer was done inner roached out). while I was at it, everything rubber in the water pump, all gaskets etc. Re tapped all holes, rethreaded all bolts. (took 2 weeks to get all parts.. Purolator was running behind!)
4) Rewired 100% the boat, removing all crimp automotive connectors, and replaced with waterproof solder ones.
5) Cleaned up all wiring in aft 1/4 birth,
6) Added one bilge pump (1-2 more coming)
7) Pumped sink into a shower sump... then out the boat. (no "T" joint in the hose out the back of the boat)
9) Installed the quick disconnect motor coupling and build a bracket for it.
10) 2 Coats VC17
Did a lot of work.. waited a lot for some pretty standard parts to arrive.. but dropped it in no issues.. wife did not freak out.
Things left to do.
1) Adjust idle on outboard... runs fantastic.. but want to run a tank of gas/carb cleaner through it as it will stall at idle. BEFORE I mess with idle set screws.
2) Figure out where the heck all the cushions actually go.. driving wife nuts trying to figure it all out ..lol
3) Lube some of the moving things and stuff..
Overall impressions from people at the club/dock/friends helping.
1) A Lot of room in the boat!
2) Motoring was a BLAST
3) Handled very well.. and rode better them some of their motor boats.
4) Many people thought the boat looked nice (but.. many people had some old banged up boats too.. lol)
5) Were very surprised it was the " MacGregor that many people rip on."
6) Mast raising system was brilliant and so easy to use (many in the marina have been dropped a few days ago.. but only 1-2 have masts up)
7) Loved the trailer aspect and that it was so large (for its type of boat)
Questions
1) Do the big pillows, with the strap with the bump on the end.. does the bump tuck UNDER the bottom cushion, or behind the fiberglass wall panels? (Or some other way)
Thanks to everyone for all the help along the way!
Regards
AD
