OK, so I've tracked down the only remaining leaks on my MacX and I found the first one where the steering linkage comes through the starboard side of the transom, and the second one was nearby at the hole for the cables.
Has anybody found a good solution for sealing these two holes? Is there any sort of boot or other sealing method that really works?
Boots for Steering Gear & Cables - stop the flood!
Motorwell Boots
Ours (installed by previous owner's outboard installer)
I assume our steering shaft boot came from MacGregor
There's also a long bellows boot you attach to the steering shaft on one side and the tube the shaft runs through on the other. We don't have one of those.
Moe
Moe
- kmclemore
Thanks, Moe! I've got a similar boot on my cables, but it leaks like a sieve - maybe mine is just perished and I need a new one? However, I'm clearly missing that other one on the steering shaft - I have nothing there on mine - the shaft just goes right through the glass and I can see daylight around the gap between the shaft and the 'glass. Not good.
Kevin,
It's summer... time to sail. Glop some RTV on 'em for now and then this winter pull the cables and wires out of the outboard and install a solid boot (and some wire loom or tubing over the cables and wires). You might even consider preemtively replacing the steering cable, or at least pulling it to put some boots on. Winter's the time for that stuff.
Moe
Moe
