Nope. Can't keep it running now. What I've done:
- Swapped hoses (all new from new tanks)
Replaced water separator
Added a ball valve to select tanks.
Replaced fuel filter in engine
Replaced the female fuel connector on fuel line to engine (the male side on the engine is next when it arrives)
Replaced and gapped plugs
Seemed to have a clogged "pee" tube, got that cleared and water flows fine (when the thing ran).
- Prime engine until bulb is firm.
Flip up high idle lever
Start engine - sounds like it's trying to run, but won't.
Sometimes runs a few seconds and dies.
- I don't see much fuel running through the filter
When key is in 'on' I hear a very faint click in the engine.
Very faint sound from the high pressure fuel pump
Checked voltage at the plug - verified 12v for 3 seconds after turning key on.
I'm thinking the high pressure pump is faulty, and only runs when motor is moved/tipped enough for some fuel to get into the line to the engine
- How loud is the pump when its running and sucking fuel before starting?
I'm sure I have heard the whirring pump sound from our ATV, Motorcycle, Bayliner...when turning the key.
I think it should have a noticeable sound, but not hearing it.
Someday, we'll try to sail/motor this thing, but just throwing money and frustration so far.
Tom
